Question about RCA D52W19 52" Rear Projection Television
  • kuberkh Mar 25, 2008
    Chirping little noise 3 times and the led on front flash 3 times but TV never switch on. Please help.
  • tommyboye83 May 19, 2009
    i hit the power button and it just makes a chirp noise like it wants to come on and it does this about 3 times. the green power signal on the front goes on and off with the chirps
Yes it does... im having the same problem as well....
Posted on Aug 10, 2010
  • 1,030 Answers
Describe noise.. Chirping 3 times? does the led on front flash
Posted on Mar 10, 2008
4 Suggested Answers
  • 979 Answers
SOURCE: Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Posted on Dec 12, 2008
  • 5138 Answers
SOURCE: rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Posted on Feb 14, 2009
  • 1810 Answers
SOURCE: rca tv wont come on at all
there is an inherant problem with rca tv's
they are not vented properly as far as im concerned
right in front of the fly back is a small part in mine it is grey i think it's a resister
when i took the back off i saw that it was sparking on 1 end ( wholy chit ) scared the **** out of me
if your chip is sparking try this fix if not turning on or no pic look inside and look for burns vthere a tell tale sign of over heating
what i did was crazzy but it worked
i took the stupid chip off by pulling on it what the puck it was screwed any how
then took it to my local electronics store they tested it and told me it was fine just had to but a new 1 since i broke a pin on 1 end
nothing grinding down ends of the case and adding some wire to the pins so i had somthing to solder to
the i re soldered the thing back to the board dam thing was trickey but as long as you are smart and gentl and for god sake un plug the set there is 600 volts inside if not more that can kill you near this chip
it now works fine my 52 inch tv has cost me $7.00 in gas and about 3 hours of time
what i noticed was that the chip over heated at the solder joint and burnt the hole bigger so i soldered and wired to the next conection and re soldered it carefully i did not remove or un plug any thing i just remeoved the board from it's slide mount and carrefully tiped t of only poping 2 conections witch were easy 2 put back on the tv is great it just hates running for 6 monthes at a time hell you shut off your $500.00 computer every once and a while dont you ???
then why would you not shut off your 2000 dollar tv every day
well hope this helps all or at least some of us who cant afford a high priced repair person to show up and tell us it will be 3-400 to fix but they will give us 50.00 for the old chasie and fix it and re sell it for 500 in a refurb tv store like factory direct in canada
Posted on Feb 16, 2009
Sorround sound switchboard lit up and quit working.
If the fan is making weird noises there is either something wrong with the bearing or it has ingested something.
Maybe you could look, listen closely and determine which it is. If it's foreign matter you may be able to extract or vacuum it out. If it's just bearing noise, you have to decide how bothersome it is and if a shop visit is justified. A clog is BAD because the fan is protecting the unit from high temperatures.
Feb 17, 2010 | RCA RTD300 System
RCA D52W19 rear projection tv wont turn on
Try this. Change the channel of your TV to 3, do you see a picture, if not. Unplug your system for the TV. Turn off and unplug the TV. Leave it off for about 10 minutes so it can discharge. Turn back on the TV and see if it re-sets. If this does not work let me know. Give me a detailed report including any brand or models you are asking about. Hope this helps.
Oct 04, 2009 | RCA D52W19 52" Rear Projection Television
Tv wont turn on r52wm24yx51 cant see the next number
Replace CP150, CP120 and CP114 on the deflection board. You can get the repaor kit at the following link listed under RCA repair kits
Aug 29, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52 in When my set is Immed, turned
Jul 15, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Feb 14, 2009 | RCA D52W19 52" Rear Projection Television
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
Wont turn on
FBT is most likely to be bad cost depends 150.00 maybe more .
Dec 12, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
258 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
