Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 paper feeding problem
Paper is not feeding into the machine from the rear paper input. It seems that the feeder is not grabbing the sheet at all. Of course this generates an error.
It seems like even though the paper is not feeding into the machine, the printer starts to print, then tries to advance the sheet again as it would during normal printing, and then realizes that there is no paper.
I know this is an old machine and not worth much, but if it can work correctly it has more value than it would as eco-damaging waste.
Thanks for your help.
  • Roger42 Mar 06, 2008
    Ooops, this machine is actually an 1820c not a 2820. Sorry.
An easy fix would be to try to clean the paper feed rollers in the paper pick up area with a gentle cleaner like soap and water or simple green. Do not use alcohol as this will break down the rubber over time. If this doesn't work, you may have drive problem and will need to refer to a professional to resolve.
Posted on Mar 12, 2008
How do I fix the paper feed mechanism
Try to rep[lace the paper separation rubber.
May 21, 2014 | Brother IntelliFAX 2800 Laser Fax
Don't know what you mean by "large quantity" of paper.???
The ADF (Automatic Document Feeder ) has a Max. capacity of 20 sheets(depending on paper thickness.)
Jan 12, 2011 | Brother IntelliFax-2820 Laser Fax
Brother copier paper feed grabs 2-5 sheets at a
check the feeed rollers ateh seperation roller the one that seperates the pages is worn.. it has proberly worn the tread and if its sn=mooth or worn it wont stop multi feed
Jul 29, 2009 | Office Equipment & Supplies
Original jammed in fax feeder of Brother Intellifax 2800
lift document feeder cover and look for paper. if no paper is present there are one or two switch levers that are on the bottom of feeder cover. make sure they can move freely and are not stuck.
May 27, 2009 | Brother IntelliFAX 2800 Laser Fax
My fax2820 says no paper feed, but paper is in the tray
first off, make sure that the paper stop at the rear of your paper in cassette is not pressed too tightly against the paper. leave about 1/8" gap. also, might be your feed roller needs cleaned, but the first scenario is fairly common.
Mar 30, 2009 | Brother IntelliFax-2820 Laser Fax
Paper tray not lifting the paper up for the initial paper feeder
most common problem on these is the rear paper stop pressing too hard against the rear of paper causing paper not to lift. make sure you have about an 1/8" gap.
good luck,
Jan 09, 2009 | Brother HL 5250DN Laser Printer
I have an Intellifax 2820 and there is an error message of paper jam inside... I have cleaned all paper out of machine... please help me
A jam sensor may be stuck by a paper scrap. Try manually pushing a sheet of paper through the machine IN THE DIRECTION IT IS NORMALLY FED. This may force out any stuck scraps. The jam sensors are usually located where the paper feeds and where it exits the machine. Also, make sure ALL ACCESS PANELS YOU OPENED TO CLEAR JAMS ARE CLOSED PROPERLY. Otherwise, the jam code will not clear.
Nov 25, 2008 | Brother IntelliFax-2820 Laser Fax
Brother 2820
Any clicking noises? Can you make a good copy? Paper seems to be dragging thru the doc feeder. Gears could be stripped, cover may not be closed tightly.
Aug 13, 2007 | Brother IntelliFax-2820 Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
491 people viewed this question
James Cagle
James Cagle
Jim Keysor
