Question about Linksys Wireless-G WRT54G Router
    Problem Solver:
  • 12 Answers
I don't think you need any disk to reinstall your routet, you just write its adress into your browser. Useally the adress is like could also be 0.0.
Try it
Posted on Mar 06, 2008
First make sure that there is no non-boot disc in either the 3.5" or the CD drive. If those are not the problem, your hard drive has either failed or lost the Master Boot Record information. You will need a Windows Install or Upgrade CD for your computer's OS. (You may also need a 3.5" boot disc for the OS.) What OS are you using on that computer. Alternatively, some third party repair software or Partition Management software can restore the boot information if the hard drive is still viable.
Try to boot to the CD and choose repair. Go the the Command Prompt (Recovery Console). Then for XP, try the fixmbr command. You can check if there is any viable data on the hard drive by trying to change drives and then typing dir to get the directory list. Try C: (enter) dir (enter). Look for a Windows folder. (Note: some computers have a recovery partition. Don't mistake that for your Windows drive.)
If your hard drive has failed, you'll need a new drive. Then use the license on the computer and an install disc for that original license. Please note: the recovery disc if you have one often doesn't work with new hardware. You will lose any third party software that was installed by Compaq. You'll need to reinstall your own software.
I hope this helps. Please add more information about your computer for additional support. If you do not have an OS disc, search for a member of a Windows User Group in your area. They often have extra copies.
Jan 15, 2014 | Compaq Computers & Internet
How to fix error f3 f200 002 satellite c850 IS it very costly to replace the hard drive of my pc
replacing a hard drive is a lot cheaper then a computer I know this because I work on computers for a living. By the way if you have not done a backup of your data and the hard drive you have now is completely dead as it won't run then you have lost your data. when you by a new hard drive they don't have Windows or any information to make your computer run, so you will need a windows Operating system disc to reinstall Windows on the new hard drive.
Oct 03, 2013 | Toshiba Satellite A65-S126 Notebook
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
My samsung Q45 notebook tells me to insert the windows installation disc and restart my computer. I have not got this, can anyone help?
First disconnect any external devices connected to the computer except the mouse and keyboard.
This error usually happens if the hard drive is not getting detected by the operating system or due to bad hard drive.
First check if all the physical connections to the computer are set correctly.
If it is a laptop remove the laptop battery, wait for 5 minutes and then connect back the battery, check if it works.
If the above step does not work then you will need to run CHKDSK tool to check if there are any bad sectors on the hard drive would suggest running chkdsk which would scan for any bad sectors on the hard drive and if those errors are repairable if would repair and if it cannot at the end of the chkdsk scan you would see a message "found one or more unrecoverable error on the hard drive" which means the hard drive is damaged.
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
1. Insert the installation disc.
2. Restart your computer.
Click the Start button, click the arrow next to the Lock button , and then click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note: If your computer is not configured to start from a CD or DVD, check the information that came with your computer. You may need to change your computer's BIOS settings. For more information, see BIOS: frequently asked questions.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7. On the System Recovery Options menu, click command prompt and in the command prompt typechkdsk /f and wait till the scan is completed and later restart the computer and check what happens.
Important: While performing chkdsk on the hard drive if any bad sectors are found on the hard drive when chkdsk tries to repair that sector if any data available on that might be lost.
Hope this helps!
Jul 09, 2012 | Samsung Q45 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I took my computer to a tech company to fix and
buy an external hard drive and just back up all your information to that or burn your information to a CD. You will want to download a program called Belarc Advisor and run it then print out the information it gives you so you have all the product key codes. Then go ahead with the reload once you feel you have copied all your information to another source.
Jun 30, 2010 | Dell Inspiron 8600 Notebook
Lost hard drive!
If you have the "System Restore" set of CD-ROMs that were shipped with the computer, you can use them to reinstall Windows to the "factory" settings.
If you no longer have those CD-ROMs, contact Fujitsu, and order a replacement set. $20 ? $20 for courier-shipping?
Nov 14, 2009 | Fujitsu Siemens Computers & Internet
Hp Pavilion 6701 desktop with ME. Installed Xubuntu OS and removed ME. Want to reinstall ME but recovery disc won't work.
Hard disk needs to be reformatted--start machine and press correct key when "setup" appears in first dialog. Remove hard drive in first screen, then reinstall. Restart computer, should now say: "operating system not found". You need original Microsoft OS disk to reformat drive and reinstall ME. All previous information on hard disk will be lost with this procedure. Recovery disk is used with original OS before Ubuntu. If you don't have original MS disk, suggest going to XP.
Jul 06, 2009 | Computers & Internet
Ive lost the disc softwear to set it up
go to Click Software and drivers downloads. Select your printer and the Operating system like Windows XP or Vista. Save it on your hard drive and reinstall the driver. Before starting the installation make sure to disconnect the printer from the computer first.
Oct 17, 2008 | HP Office Equipment & Supplies
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
