Question about HP 12c Calculator
Number 6 on Key Pad, not working
I've had an hp 12c plat for about 2 years. Yesterday I noticed I was having to press the number six several times to get the number to display and today it's even worse. I use this calculator every day, but it has been baby'd. Any suggestions??
  • 1 more comment
  • zuidlaren Mar 31, 2008
    HP 12C - when # 3 button is pressed nothing happens, can this be
    repaired ?..
  • Curtabennett Apr 16, 2008
    The number 6 on my hp 12c doesn't work. Is it worth repairing?
    Curt@curtbennett.com
  • kotosh May 13, 2008
    Yes I do, but with "Zero" and "+"symbol. I have been wondering if, there is some one who knows how to fix it.
    Best regards
I had the identical problem. One of the fixya folks helped me disassemble the calculator, which I did (there are about 6 plastic rivets which must be reamed away before the circuit board can be lifted out). Be careful not to lose the grounding springs which go back through the two hollow plastic posts. Pull the white sticky covering back carefully, noting which contact represents the "6". Clean the contact area as described but also make sure the contact is in the dead center of the "cut outs" in the sticky film area. When reassembling, I put a small piece of ace bandage between the board and the back of the calculator (towards the bottom, do not block the metal plate where it contacts the "spongy metal" grounding box). This is needed for support since the rivets have been removed.Carefully reassemble everything including the springs. Mine worked perfectly afterward!
I do have a theory that the magnets used in the "anniversary" case have an adverse effect on the calculator. Just a hunch, since one sits over the "6" key. I don't use that case anymore. Sorry they don't make 'em like they used to!
Posted on Sep 18, 2009
  • khlusk Jun 17, 2011
    I had and issue where the 6 key would not work consistently and at times had to hit the key very hard to have it work. I am not as mechanically inclined as some of the others so I just used some wd 40 and put in on the key and let a couple drops get between the key. So far that solved the problem. I am hoping that the WD 40 will evaporate and the 12c will continue to operate for some years to come. It has been a few days and so far it is still working great.
Thanks for the posts guys! incredibly my calculator started have a problem with the 0 key 2 days before the exam. i would have had to spend $100 if it weren't for your post!
Posted on Nov 19, 2011
    Sergeant:
  • 329 Answers
Not sure on that model, but if you are handy, remove covers carefully and the keypads are usually made of two layers a small magnetic dot embetted in rubber and a circuit board. cleaning the magnetic dot with windex or even rubbing alchol, and using a pencil eraser lightly clean the small circuit booard. Smae machines actually have a switch which if you can find the switch it can be replace...good luck
Posted on Jun 28, 2008
WHAT IS USED FOR THE EQUAL TIME
The calculator is doing exactly what you tell it to,
You first input 1.06. Then you press the y*x key, which tells the calculator to raise the previous number on the stack to the 1.06 power. Then you input 10. The result of all this is 10, as your calculator shows.
If you want to raise 1.06 to the tenth power, press 1 . 0 6 ENTER 10 y^x.
My 12c shows 1.7908 for the above.
Sep 08, 2016 | HP 12c Calculator
How do i get change in days
From page 31 of the manual in English, available on HP's website at the link below:
Number of Days Between Dates
To calculate the number of days between two given dates:
1. Key in the earlier date and press [ENTER].
2. Key in the later date and press [g][?DYS].
The answer shown in the display is the actual number of days between the two dates, including leap days (the extra days occurring in leap years), if any. In addition, the hp 12c also calculates the number of days between the two dates on the basis of a 30-day month. This answer is held inside the calculator; to display it,
press [X><Y]. Pressing [X><Y]again will return the original answer to the display.
http://www.hp.com/ctg/Manual/c00363319.pdf
Sep 26, 2014 | HP 12c Calculator
Cpt button
There isn't one. Unlike calculators from other makers, the 12C knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 12C.
Aug 30, 2013 | HP 12c Calculator
Cpt button
Cpt button 12c calculator
Unlike TI calculators, the HP 12c doesn't have or need a CPT button. It knows whether you've made a numeric entry or not. To calculate N, I, PV, FV, or PMT, simply press the appropriate key without entering a number.
Feb 22, 2012 | HP 12c Calculator
HP12c seems to not have enough room for numbers BEFORE the decimal point. I try to enter the number "85" and all that will show up is the 8.000000000
Initial Setup
One adjustment is important before we get started. By default the 12C displays only two decimal places. This is not enough. Personally, I like to see five decimal places, but you may prefer some other number. To change the display, press "F" and then the number of decimal places you wish to display. I would press "F 5 " to display 5 decimal places. That's it, the calculator is ready to go.
You need to hold the "F" key.---------
    1. Press and release the gold PREFIX key (f).
    2. Press the number key for the desired number of decimal places (0 through 9).
------------ Click this link below and follow the procedure:--- http://howtobyme.blogspot.com/2011/07/hp-12c-calculator-help.html
----------- This should help.Thanks.Helpmech.
Jul 21, 2011 | HP 12c Calculator
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
Minolta Di183 display shows 88
1 Call the Utility Mode to the Display.
❍ Calling the Utility Mode to the Display (p.7-1)
2 Making sure that “U--” appears on
the Display, enter “5” from the 10-
Key Pad.
3 Press the [Start] key.
Enter the 6-digit administrator
number from the 10-Key Pad.
? Do you know how to enter the
administrator number?
➜ Enter the six digits successively.
? Do you want to correct a wrong
number just entered?
➜ Press the [Clear] key and then
enter the correct number.
5 Press the [Start] key.
6 Check that “Ad-” appears on the
Display.
7
Enter the code assigned to the
desired subfunction from the 10-
Key Pad.
? Do you know the code for Copy
Track?
➜ To select Copy Track, enter “1.”
? Do you know the code for Disable Auto Shut OFF?
➜ To select Disable Auto Shut OFF, enter “2.”
8 Press the [Start] key.
GO to Konicaminolta US website down load a operators manual free
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 26, 2009 | Minolta DiALTA Di183 Copier
Change phone number
Hi, Below are the instruction for that. You can find the full operators manual at
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=fax2820_us_as&type2=8&flang=English&dlid=
Hope that helps...
Lbcoaster
You should store your name and fax number to be
printed on all fax pages that you send.
1 Press Menu/Set.
2 Press 0.
3 Press 3.
4 Enter your fax number (up to 20 digits) on
the dial pad, and then press Menu/Set.
5 Enter your telephone number (up to 20
digits) on the dial pad, and then press
Menu/Set.
(If your telephone number and fax number
are the same, enter the same number
again.)
6 Use the dial pad to enter your name (up to
20 characters), and then press Menu/Set.
7 Press Stop/Exit.
6 Set the Date and Time
Year:2007
Month:03
Day:01
Time:15:25
If you make a mistake, press Stop/Exit to
start from Step
1.
7 Set your Station ID
Fax:_
Tel:_
Refer to the following chart for entering
your name.
If you need to enter a character that is on
the same key as the previous character,
press to move the cursor to the right.
Press
key
One
time
Two
times
Three
times
Four
times
2 A B C 2
3 D E F 3
4 G H I 4
5 J K L 5
6 M N O 6
7 P Q R S
8 T U V 8
9 W X Y Z
For more details, see “Entering Text” in
Aug 01, 2008 | Brother IntelliFax-2820 Laser Fax
HP 12c Calculator Logo
437 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
