Question about Protron PLTV-26 26 in. HD-Ready LCD Television
NO SIGNAL NO PICTURE - NO SOUND - BLACK SCREEN - ALL CABLES CONNECTED
    Master:
  • 351 Answers
Dear Dresden,
maybe the Main PCB or Power Section of your LCD TV. call the Authorised Technician ,he will fix it onsite.
Regards
Posted on Mar 07, 2008
  • 100 Answers
Better to u take from nearest service center.I think,some IC's problems is in ur LCD.
Thanks
  • Protron Master
  • 19,396 Answers
Check all cables and connection, Then check fuse in connection to power outlet. If it still does not work then power supply inside tv may need to be replaced
    Sergeant:
  • 406 Answers
Press power and test or reset button on Remote control.
Else Put it on Auto Tune.
Regards
Rafique
Tv troubleshooting tv sound is good but no picture
Make sure that the video cables are connected securely. Adjust the contrast and brightness. Make sure the correct video mode is selected. Make sure the incoming signal is compatible. Make sure the antenna or cable is connected correctly. Check the closed caption settings. Some TEXT modes can block the screen.
Oct 10, 2013 | Dynex Televison & Video
No picture, but light blue screen. Can hear sound.
Make sure the video cables are securely connected and adjust the contrast/brightness. Make sure the correct video mode is selected. Make sure the incoming signal is compatible. Make sure the antenna/cable is connected correctly. Check the closed caption settings. Some TEXT modes can block the screen.
Oct 09, 2013 | Insignia NS-LCD26-09 26 in. HD-Ready LCD...
Dynex lcd sound but no picture
Adjust the contrast, color, and brightness settings. Make sure the video cables are securely connected. Make sure the correct video mode is selected.
Make sure the incoming signal is compatible. Make sure the antenna is connected correctly.
Check the closed caption settings. Some text modes can block the screen.
Sep 16, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
Black Screen - No Signal when connect Bluray to TV with HDMI
I just had the same issue and I believe it was because the sound bar was turned off. The solution was turning on all of my connected equipment such as my sound bar, cable box, tv, blu-ray player, and internet router. It stopped "disconnecting" after only 30 secs of being turned on. I think it was because my husband connected it to all those things in some way so the settings are set to work with those pieces of equipment. With one powered off, in my case the sound bar, the signal can't run full circle and reads as if cut off. Please excuse my nontechnical terminology.
Dec 28, 2011 | Philips BDP3000 Blu-Ray Player
L42wd22 "no signal" and no audio
Exactly one year ago our TV did that. Now our TV is in the service center cause it has no screen.....just a plain black screen. However last year when we had it in we had that "no signal" message. It was not the same problem. It had something to do with wiring on the master board...thank gosh for warr. Otherwise I was told it would have been a $300-$500 repair.
Best of luck!!
Apr 21, 2010 | RCA L42WD22 42 in. LCD Television
The picture is green
Make sure that the unit is connected to the tv properly. Be aware that most dvd players have six connections. You can connect the unit to the television using RCA cables (yellow, white, red) or RCA sound with component video (white, red, blue, green, and red). When using the yellow-white-red method, the sound is carried by the white and red cables and the video signal is carried by the yellow cable. If you're using the white-red-blue-green-red method, the white and one of the red cables carries the sound, and the blue-green-red cable carries the video signal. This connection uses one cable for the green component of the picture, one for the blue, and one for the red. Make sure that the cables are connected properly and you don't have the two red ones mixed up. Connect Sound-R to Sound-R, component R to component R, etc. If that doesn't work, you may be able to adjust the picture on the tv. There's still a chance that the machine is defective.
Mar 08, 2010 | Daewoo DVRS04 DVD Recorder/VCR
No image, sound is on
check the rca cables, specially if they the chep kind, I had so many problem with these cheap rca cables I quit buying the cheap kind, they give me too much prblem.
Aug 12, 2009 | Initial Televison & Video
No sound on play back using camcorder on technika tv
Looks like you are using Component cables. There are five cables. The first three cables are Green,Blue and Red. These are the ones that are molded next to each other and are the Video signal cables. The other two cables are Red and White and they are the audio cables.
First to correctly hook up these cables you need to Connect (Match) Color for Color. (Green to Green, Blue to Blue, and Red to Red. To tell if you have correctly connected the Video cables is to look at the screen. If the picture looks ok (Normal with no colors missing then you have connected the video cables correctly). If you see a missing color meaning red, then switch the Red cables. The picture should be ok now. The remaining two cables are the Red and White cables. The "Red cable" is for the "Right" audio input and the "White" cable is for the "Left" audio Input". If all is connected correctly then you should have a good picture and Left and Right audio.
Jul 05, 2009 | Televison & Video
Xbox 360 no picture but sound, works on another HDTV
did you check to see if the av conponent was on tv/hdtv?
Nov 15, 2008 | Microsoft Xbox 360 Console
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Protron PLTV-26 26 in. HD-Ready LCD Television Logo
65 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
