Question about Toshiba 55H70 55" Rear Projection Television
Toshiba 55pj6db rear view projection tv
Hi there am standing at the back of the tv with the inspection panel of which side is the convergence board so i can take it out
  • benny1951 Mar 07, 2008
    Hi there am standing at the back of the tv with the inspection panel of where would i find this on the left side or the right front of the tv or the back where am standing also what do they look like
    Hi theres quite a few silver plates in the tv is it the lerft or the right side would it be at the back or the front
    Brigadier General:
  • 3,614 Answers
The one which you casn see the STK chips.
Posted on Mar 07, 2008
  • micromaster
    micromaster Mar 07, 2008
    The one with the silver plate. That the convergence IC and that the convergence board
  • micromaster
    this one like
    Guru:
  • 1,894 Answers
Hello
  • dewan nafees ahmed Mar 07, 2008
    clip the legs off the STK39s-110's to make removing the rest of the
    pins and solder from the board easier,
The picture bottom centre has gone out of shape. For example some one standing to the side in the picture looks pregnant. The picture is out of shape please help ;(
Tv have a problems,known as a convergence problems it is dead.Tv have R,G,B colors lines mis alignments,have colors shahows pictures or 3D pictures look alike?Yes,the tv convergence board it is dead.Convergence board must be replaced 2 STK convergence ICS and some or all of it resisters too.To fix the convergence board to fixed the tv convergence pictures problems.The shop will cost u like $300-350 for parts and labors.
Jun 05, 2011 | Toshiba 50A61 50" Rear Projection...
What causes the yellow and blue ghost on tv, and how to solve it. It is on a Toshiba rear projection
The problems ur tv have is known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 25, 2010 | Toshiba 55H70 55" Rear Projection...
So the colours match up on the left hand side of the picture, and progressively fan out towards the right. The convergence had to be lined up manually for to come to this view. As well the picture has...
The "Hyper board" known as the tv convergenece board,it dead.Any colors lines R,G,B mis alingnment anywhere in the picture,have colors shadows pictures or 3D pictures.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts,must be changed on the tv convergence board,to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 13, 2010 | Toshiba 50HDX82 50" Rear Projection...
Toshiba Big Screen Tv Has Bad Colors
this is a rear projection tv not lcd the color is off because the convergance chips are bad take the board out that has the tow stand up chips attached to heatsinks out order the stk number search for on google then take a om meter check all the resistors aroung the chips replace them also you must be a excellent soilder person or a tech to install and remove these chips
Oct 19, 2009 | Toshiba 32 AV 500 PG 82cm 32 in. LCD TV
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Jvc tv 56 convergence problem
on the 48WP30, you get to the convergence board through the front. Around the back edge of the speaker grille are four screws. You remove these screws. Then you remove the two other screws at the top of the speaker grille near the center panel underneath the front av input door.
THen after you get the speaker grille off, you take the four screws out of the wood panel door and take it off:
Those two big black heat sinks on the front there are your SK chips...on the convergence board of course. pop it up from those four tabs, and that will let you carefully move the convergence board so that you can reach in better, and unhook the three plugs on the right side (looking at it from the heat-sink side) behind the heatsinks (one for red, green, and blue each) and then on the other side of the board, you disconnect the other two plugs, but there's one that you actually have to trace back into the inside of the TV and unplug from a vertical standing board, since the socket is not on the convergence board itself. let me draw up a little graphic real quick.
Hope that helps.
Oct 23, 2008 | JVC AV-48WP30 48" Rear Projection...
If the board was "repaired" the settings should not have changed. There is a particular order to performing a convergence alignment. Do a web search for the service manual that will document the specific steps you need to take. Search using the model number and the keyword "manual". It should be availabel for $10-$15.
Dan
Mar 17, 2008 | Televison & Video
Samsung 52" tantus pch521r convergence panel
I found a this SITE that carries that convergence assembly for your TV.
Good Luck.
Mar 10, 2008 | Samsung PCH521R 52" Rear Projection...
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
...................................T.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
188 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
