Question about Dell Dimension™ 4600C PC Desktop
Dell Dimension 4600C will not power up
4600C gives power to mother board ( light is on) . When you hit the power button switch on front if unit, power supply fans turns for a second or two then stops. machine will not power up, and switch light on front blinks yellow.
Unhooked most devices such ad modem board, Ram, Audio connectors, etc, and still no power up. The switch seems to be relayed through a small board behind USB Front ports that hooks to the mother board.
  • paul48 Mar 07, 2008
    Is there any way of figuring out what is gone of is it just a guess. I certanly don't want to purchase a motherboard or Power supply if I don't need it.
  • Anonymous Dec 09, 2008
    I have the same problem except my yellow light doesn't blink. It's consistant.
  • 492 Answers
Sounds like the power supply is faulting. If not it is your mother board that has failed.
Posted on Mar 07, 2008
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
When plugged in, my dell 4600c will not start up, and the light on the front of the tower stays yellow. Is this a power supply issue, a hard drive issue or a motherboard issue?
The only real way to test all is to have a 2nd pc. You can even unplug the hard drive from the motherboard just to test the MB and power supply. The bios will still load without a hard drive attached to it.
Dec 21, 2009 | Dell Dimension 4600C PC Desktop
Dell Insp 4600C blinking yellow power light
the issue could be woth the power supply unit or internal wirings ..
Jul 19, 2009 | Dell Dimension 4600C PC Desktop
Yellow light on dell dimension 2400 and it won't work
HI, this is signaling an issue that is concerning the power unit(power supply). this can also be an issue with the mother board as well. you can confirm the actual issue by, inspecting the cooling fan that is on the power unit. if the power unit fan is not running when you push the power button to power up the PC, replace the power supply. if the fan is running, replace the mother board.
Jun 21, 2009 | Dell Dimension 2400 PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 11, 2009 | Dell Dimension 4600C PC Desktop
Problem with Dell 4600C
Dimension 4600C driver
Developer: Dell
Version: 1.16.0
System: Windows XP,Windows 98,Windows ME,Windows 98 SE,Windows NT SP4,Windows Vista,Windows 2000 SP4,Windows 3.11,Windows NT SP3,Windows NT SP2,Windows 95,Windows NT,Windows 2000 SP2,Windows 2000
License: freeware
http://support.dell.com/support/downloads/index.aspx? here you will find your solution
Apr 14, 2009 | Dell Dimension 4600C PC Desktop
Dimension 2400 can not power on
If you have no power by pressing the front power button and you have verified that the black connector coming from the power switch on the front is connected properly to the motherboard, then make sure that both connectors from the power supply are connected properly, the main connector and the p4 connector. Reseat both of the connectors to be sure.
If you still have no power and still have the light coming up on the motherboard then I think the motherboard may be bad cause that means something is shorting out the motherboard and not allowing power to go thru it properly.
Mar 08, 2009 | Dell Dimension 2400 Power Supply ** FREE...
Dell 4600c will not power up -- green power button lit -
i think it may not power supply problem.it may be ram memory problem.try this,remove your ram and clean it with cloth and restore back.
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension™ 4600C PC Desktop Logo
388 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
