Question about Zenith B25A24Z 25" TV
I cannot access channel 3 or 4..I dont have the remote anymore, I have a universal remote, it will turn the tv off and on but not change the channel, I went into the menu and tried to manually add channel 3 and 4 but it will not add. I tried to do it auto but it wont be found, How can I get channel 3 and 4 to add
SOURCE:
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
bkvinr
  • 76 Answers
SOURCE: can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Posted on Sep 09, 2007
jimbo4026
  • 50 Answers
SOURCE: hooked to cable...says no channel found
how old is this set? there were some certain years the auto matic scan didn't work, you must enter them under the manual way.
Posted on Nov 20, 2007
techman
  • 3130 Answers
SOURCE: Zenith Concierge hotel tv wont work with my xbox 360
There may be a door in the front of the ste that is locked. You could take off the back and see if there are any circuit boards attached to the front of the ste and then that would show you where the door would be. Sometimes they losck the door with tabs on the inside and has to be pryed off.
Posted on Mar 21, 2008
  • 126 Answers
SOURCE: In auto program only the first 13 channels are found?
sounds like bad tuner try to program manually and see if it will hold memory
Posted on Mar 21, 2009
My rca remote turns the toshiba tv on but it dont change channels
U are using an RCA remote with Toshiba tv. You are lucky that it even turns the set on. You have different remote frequencies involved and need to use the Tosiba remote or a universal remote that will operate volume, channels and power.
Mar 17, 2015 | RCA Televison & Video
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
When i hook up cable and turn on the tv all i get is a blue screen on ch 3. and it wont turn from ch 3 whats up with that...?
You have to setup the tv with using the menu. The tv will need to ''autodetect'' the available channel before it can leave you access other channel. Otherwise you may generally ''force'' a channel by using the remote and entering the channel you wish to liste. (dont you lose the remote!!!) Then in case of major problem if you cant access and navigate in the menu without it, go buy the cheapest universal remote! Take the time and you'll find the trick!
Aug 05, 2009 | Broksonic CTGV-5463TCT TV
Changing chanal
Perhaps channel 4 is the only channel programmed? Try reprogramming your channels. Perhaps a universal remote would give you direct access to the channels. Your channel up or down won't work with only 1 channel programmed.
Jul 24, 2009 | Televison & Video
I need to reprogram my rcr317w remote contact with manual
Turn the tv on. Hook up your components, turn them on, go in to tv menu and auto program the stations. It will see that there is a signal on channel 3 and lock it in for you.
Jun 30, 2009 | Universal Remote Control DIRECTV Universal...
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Connecting my tv and vcr so i can use the vcr remote control
You can always push "03" on a universal remote programmed to work your TV. A better solution is to connect the devices properly. You shouldn't use the tuner inputs for a VCR/DVD player, or you will get a poorer picture and no stereo sound. See the instruction manual for your player and TV. Use a stereo audio/video cable to connect them and select the proper input. The instructions will hopefully clarify this.
Oct 16, 2007 | Philips Magnavox 27MS343S 27" TV
Zenith B25A24Z 25" TV Logo
93 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
