Question about Eclipse AVN5500 Car DVD Player
Button illumination Most of the time when i start the car and turn on the lights, the button does not illuminate, but sometimes out of the blue when i turn on the car the buttons illuminates, it have illuminated i think 10 times out of 100. Can you help me solve this problem thank you i really appreciated.
  • endlesss122 Mar 10, 2008
    i m sorry for the late response, i was out of town for the weekend, first of all i would like to thank you for looking into this matter, i have tried to follow the wires(orange) and it is connected properly, but there is no light illumination on at all when the car is on, i wonder if it is a factory defect, but even then my warranty is over, and stupid me, i never bother with it, untill it recently comes on more often and i find it more useful at night with the lights illuminated, thanks for trying, any other suggestions thanksss
  • endlesss122 Mar 13, 2008
    hi hogan, it was so nice today, and my order for the back up camera came in, so i did as told, i tried cleaning the connector, and there is no change to the lighting, it's still not illuminating, hmm.. i don't know what else i can do, but i really appreciate your kindness to help the situation. At first i thought it was something wrong with his installation and he didn't wanna bother checking it, but i guess it's a factory defect,
    And now for my second problem, i have just installed a back-up camera,( BOYO VTL 400) and i connected as told, but there is no video showing just a blank screen, I was just wondering is it something wrong with the camera or do you think i have to buy a back-up camera from eclipse in order to work? thanks again for your time and effort, hope to hear from you soon, thanks
    Champion:
  • 227 Answers
Check see if your illuminate wire(orange) is connected properly. If it is, you should get a high illumination when your lights are off and low illumination when lights are on.
Posted on Mar 06, 2008
  • hogan doan
    hogan doan Mar 11, 2008
    On the back of your face plate. There are these connectors that make connection with the unit. Try to clean them up really good because sometime they get dirty specially if you removed it alot. Dirty connection can creat all kind of weird problems. Goodluck.
  • hogan doan
    hogan doan Mar 14, 2008
    Hi bud, you do have to get an Eclipse brand one to get it working by the deck rear view camera function. If you have a different brand it could still be use if it has rca line out or if you can get an adapter to convert the camera output to rca line and hook that up to the deck video rear input also sometime called aux input, make sure it the yellow rca input line and switch your deck source to rear video to see rear camera video. Let me know how it goes after you try it. Hogan.
2003 XKR dashboard illumination goes off when main lights switched on or if dash lights do stay on after starting they go off when main beam is operated.
is this car the all alluminium xk model ? if so it sounds like a bad earth the earth studs are all bonded to the body and are prone to detatching from the body and causing all strange probs. the favorite ones are both front behind the wheel arch liners, if its the older xk still sounds like a bad earth poss behind the headlamps. the only other probs i had was wires coming detatched/poor connection from the column switch, hope this helps
Oct 03, 2016 | 2003 Jaguar Xkr
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
I'm putting panasonic cq-c1103u player into 2001 corolla using an adapter plug. I have all the wires connected from plug to player harness, but the is 2 wires left over from the plug, the blue power antena...
unless you have a power antenna or an external amp, all those are extra wires. just cap them off. the orange wire is only used if the radio has an illumination feature that allows dimming on the radio. it is not needed to see the radio. DO NOT connect the blue/white from the radio to the orange of the harness. whenever you turn the radio on it will send 12V to your cars illumination circuit. this could damage your lights, dash lights and maybe the radios output.
Apr 12, 2011 | Panasonic CQ-C1103U CD Player
What button do I use to retrieve code?
The following procedure will work for RCR311, RCR412, RCR420, RCR612, RCR812, RCR815, D770 and other similar models.
Code Retrieval
Step 1: Press and hold the component key (TV, DVD, etc.) whose code you wish to retrieve. The illuminated ON/OFF key turns on. {Some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.}
Step 2: While holding the device key down, press and hold the INFO key. The illuminated ON/OFF key will turn off.
Step 3: After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 4: Release both keys. The illuminated ON/OFF key remains lit.
Step 5: Starting with the number 1 key, press and release each number key on the keypad in the following order: 1 to 9, then 0. The number that causes the illuminated ON/OFF key to blink is the first number of the code.
Note:
TV codes begin with the number 1
VCR codes begin with the number 2
DVD codes begin with the number 3
Satellite receivers and cable boxes, codes begin with the number 5.
Step 6: Repeat step 5 until you have retrieved all 4 numbers in the code.
Step 7: After the fourth number is retrieved, the illuminated ON/OFF key blinks briefly, then turns off.
Note: To exit the Code Retrieval Mode, press and release the "GO BACK" button at any time.
Hope this helps.
Feb 25, 2011 | RCA 3-Device Universal Remote
I run my finger over the power button but it wont turn on.
You don't need to run your finger across it, with the red light illuminated, press and hold the power button for 3 seconds you should hear a beep then a blue/green light should illuminated. If you see no light ensue the MAIN power switch on the back is switched on.
Rylan
Dec 16, 2010 | Sony Playstation 3 (PS3) Console
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Anti lock brakes
depending on the system if it is 2 channel or 4 channel one of the sensors that are located on the backing plate located behind calipers is eithier faulty or dirty you can try brake cleaner these sensors use a small magnet pickup device to sense when the wheel "locks up"
Jul 20, 2008 | 1985 Audi 5000 S
Code Search
First try this method as it is the quickest way,
To program a component using the Automatic Code Search method, perform the following steps:
1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button.
aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button.
aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s functions.
Only use the codes below if the auto code search dosen't work. Codes program a zenith tv are below
Zenith 1000, 1001, 1004, 1051, 1083, 1151, 1152,
1154, 1217
You can click the link below you will be able download the manual.
http://support.rcaaccessories.com/main.html?topicid=216&Referring%20DeviceDocID%20List%20Index=1&navtypeid=16&pagetypeid=35&prevPageIndex=13&selectedmodel=RCR450&selectedFamily=generic
Mar 15, 2008 | RCA RCR450 Remote Control
Eclipse AVN5500 Car DVD Player Logo
204 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
