Question about OKI C5500n Printer
Printing index cards on oki printer
How do i print on an index card on an oki printer?
I changed the settings on media to rough paper & made sure all paper was to come from mp tray, but it does jam frequently, and every time it does, i need to open & re-open the front cover to get it to clear the error that appears. the error reads mismatched paper size, as there is not a custom size of small index cards of 3.5 x 5.
Posted on Mar 07, 2008
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Printer for Envelopments Metallic Card Stock
I recently purchased an OKI specifically for my stationery business as well (using metallic cardstock) and the company told me that no OKI printers work on metallic paper... I am STILL on the search for an invitation printer! Its frustrating to say the least....
Jul 15, 2009 | OKI C5400tn Laser Printer
Printing on an index card
something else you might try is taping the card to a full-size sheet of paper, so the printer can push it through with ALL the rollers at the same time. not all printers have a roller all the way across, so index cards get snagged by one side, and they'll walk to the opposite side while they're printing.
Jun 12, 2009 | Ricoh Office Equipment & Supplies
How to center greeting card paper in the printer or computer
Centre the paper tray guides. However as the papersize is quite small, the guides may not be close enough to maintain the paper in the centre.
You can either cut the paper a little bigger so as to match the tray guides and then trim the excess paper after printing.
Or you can place two pieces of cardboard or any other material of same thickness on either side of the paper so as to center the paper with the sides of the tray.
May 20, 2009 | OKI C5200n Laser Printer
Want to print pictures from camera card.
I received my Brother printer today (11/5). I also go mine mainly for the scanner because my Visioneer 9320 doesn't have any drivers for VISTA, and Visioneer isn't making any updates.
My camra uses a SD card. This is how I got mine to print pictures.
I place my SD card into the printer
I then press the PHOTO CAPTURE button The display on the printer reads CONNECTING TO PC
Then the display reads PRESS (up arrow or down arrow) & OK
When you press the up or down arrow, the display will read PRINT IMAGES or PRINT INDEX
I selected PRINT INDEX and then you have to press the OK BUTTON
The printer display then will ask 6 images per line or 5 images per line.
You pick what you want then you hit the OK button.
Don't forget to put the photo paper in the tray, upside down.
Hopes this helps
Nov 03, 2008 | Brother Multi-Function Center MFC-240C...
Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
May 22, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printing with 190gsm paper
Max paper weight is 203gsm so you are near the upper end of specs, you must feed via manual pass and exit from face up tray (out of rear), paper type(heavy/card stock) must be set on print driver. User guide can more than likely be found www.oki.com.
Dec 31, 2007 | OKI C5200n Laser Printer
OKI ML280 serial card installation
I believe on the top of the printer towards the back is a panel with a single screw. Under here are dip switches to set the printer.
Jun 18, 2006 | OKI (09002353) Serial Adapter
OKI C5500n Printer Logo
340 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
