Cannot connect my IMAC to my WET54G router. The router is connecred to my Gateway computer operating under Windows XP. I was able to connect both the Gateway and the desktop MAC to the router.
    Genius:
  • 3,587 Answers
You'll need a driver for the Imac for that router..is that a linksys by chance?
Posted on Mar 06, 2008
Operating system: Windows XP Home Edition Model: Acer One Aspire Problem: PC sees wireless networks & connects but Internet Explorer &/or Mozilla don't get me on the internet.
please ping your router gateway,for seeing default gateway you take command prompt and type ipconfig, there you can see your default gateway then type ping gatewayip (eg: ping 192.168.0.1) if you are getting reply from that gateway your computer communicating with your router.If you are getting request timedout then there is a problen in communication.If you are getting the reply then you just ping google (ping www.google.com).getting reply the connection to the internet is fine.If not there is problen in internet connection in the router.
Jul 21, 2011 | Computers & Internet
I have an iMac g5 and an eMachine. I have internet on the iMac and I need to get it to the Windows computer. I have TONS of cords and like 5 wifi roughters. I just need to know what to do inside...
just connect both computers to the same router/hub. if mac is working then windows should work as well. on a wired network in windows xp and beyond, there is no set-up required. if it is not working, then perhaps you using a crossover cable (meant to connect 2 computers directly) instead of a regular ethernet cable.
Sep 30, 2010 | Apple iMac G5 Desktop
Change my settings from wep to wpa I have a belkin 54g
when you change the wireless security on the router , it is recommended tht you will change the wireless network name also ( SSID ). Because when you try to connect to the wireless network on the computer, your computer will try to connect to the same old network name with the old wireless security settings. To avoid this you can change the wireless network name. WPA is supported by windows XP SP2 and above operating system.
If the operating system on your computer WINDOWS XP SP1 and if you are trying to connect using the windows utility then you would not be able to connect to the network .
Click Here for more information about the routers and networking
Jan 28, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Can't ping Default Gateway (XP) From Windows 7
Make sure you are receiving a proper IP address from the DHCP server....If you run a cmd prompt (windows icon, type cmd and hit eneter, then ipconfig) you should see a 192.168.0.x address. If not, go to the control panel, network connections, manage network connections, and be sure that TCP/IP (V4) is set as auto-configure....
If you are sharing the connection through an XP computer, you will need to run the Internet and connection sharing Wizard on the XP computer, and transfger the settings on a disk to the Windows 7 PC. A simpler solution (assuming you are on a cable/dsl connection would to be to go to your local big box store and buy an Internet/Firewall router. It would also increase your security.
Dec 28, 2009 | Microsoft Windows Vista Ultimate Edition
I have a trendnet wireless router tew 432brp, a new hp windows 7 laptop, and old xp laptop and i want to share the connection with my verizon um175 aircard. this has worked for several years with the old...
The router connects computers together . You are using a windows 7 p.c and connecting it to an internet connection via a usb verizon um175 aircard.
I think you need to share the internet connection with the rest of the network and may need to feed the ethernet cable into the feed port of the router. I have not done this before but logically the windows 7 computer would have to act as a gateway to the internet.
http://www.dummies.com/computers/operating-systems/windows-7/how-to-share-an-internet-connection-in-windows-7/
https://www.ibvpn.com/billing/knowledgebase/53/Internet-Connection-Sharing-on-Windows-7.html
Note the default gateway is going to have to be the windows 7 ip address on the other computers
You may need to set the ip address on windows 7 to a static address and then change the dhcp server settings default gateway and also increase the first address to not include the windows 7 ip address or the routers ip address in the lease range for shcp.
Mar 17, 2017 | Trendware TEW-432BRP 54Mbps Wireless...
No internet connection with Siemens 587 router / Tiscali
Try this... power down your modem, router, pc and imac, then power up in this exact order, modem first, then router then the computers and see if that works for you...Hope this helps!!
--Joshua79
Apr 06, 2009 | Computers & Internet
Making a wrt54gc wireless router work with a wet54g bridge
You shouldn't have to enter your SSID unless you have it hidden. Also, make sure you have the correct encryption set on both sides. WEP/WPA/WPA-2 for the Security type and TKIP/AES for the Encryption type. They need to match your router.
Also, you need ot make sure you are entering the correct IP/gateway/subnet mask address or have DHCP enabled.
Good luck
Jan 29, 2009 | Linksys : WET54G Wireless-G Ethernet...
Imac AirPort Extreme (0x14E4, 0x8C) to wifi
On the iMac choose Create Network... from the Airport menu. Then the Gateway laptop will be able to join the iMac's created network.
macs2u
Dec 29, 2008 | Apple AirPort Extreme Base Station...
Unable to get my WET54G up and running
Make sure that you routers IP range is setup to handle the IP address of your PC.
Feb 02, 2008 | Linksys Wireless-G WET54G 802.11g/b...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
