Left click in top right corner on the three bars...click on Settings...scroll down and click on Show Advance settings...click on Content settings...click on All cookies and site data...click on remove all...close broswer...open broswer back up...pages will load faster as you open new ones...
Push your camera's settings button (next to top button to left of LCD) and, using the left, right, up, down arrow keys, scroll down to the "Custom Setting Menu". Scroll down to "(d)Shooting/Display". Push the right arrow key and scroll down to "( c4)Monitor Off Delay". Push the right arrow key again and you will be able to choose set the delay between 4 seconds and 10 minutes.
With the dryer OFF Press the following sequence of buttons My Cycle - Delay Start-My Cycle - Delay Start . Menu will come up. Scroll down to Error codes and select. Scroll using arrows through error codes
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press: 1.Add 2.Option # 3.17 4.Use the numbered keys to enter the time 005 - 254 seconds (all entries must be 3 digits). 5.DONE To turn off Dialer Delay, press: 1.Delete 2.Option # 3.17 4.DONE
Type "about:config" in the address bar when the settings load right click anywhere on the screen and new then click intergar the name will be "Nglayout.initialpaint.delay" and the vaule will be "0" click ok... That should help if not than you may need to uninstall and reistall firefox.... This isn't realative for your problem but you can also speed up your broswer by scrolling down to "network.http.piplining" and make the value true... then below it where is says "networking.http.piplining.maxrequest" Change the 4 to an 8!
In the shooting mode, press the Func/Set button. Scroll down the icons to the 'drive mode' icon (a square). Then scroll right to the icon showing a circled 2 (2 second delay) or a circled 10 (10 second delay). Press the Func/Set button to select.
To return to normal, use the same procedure, but select the square icon (single shot).
please remove your hidden files from your drive c, by using nero software burner. also remove or delete your temporary internet files. please rate me. thanks.
A connection from USB adapter directly to USB adapter may or may not be possible. Borrow a wireless router from someone and use it to test supporting connections to your two computers. I think you will find this a much easier way to proceed. Routers can be had for $40 or less. Shop around.
1. Press the Func/Set button.
2. Scroll down to the Drive Mode icon (rectangle) on the left side.
3. Scroll over to 2 sec or 10 sec delay icon (clock with 2 or 10)
4. Press Func/Set button.
To return to normal shooting, select the single shot (rectangle) icon in step 3.
