USB ports dont work
Since downloading vista, and itunes my usb ports dont work, any suggestions?
  • hellsbelles0 Mar 06, 2008
    acer notebook
    sorry - never used this site before
    Genius:
  • 3,587 Answers
Hmmm...ok..what kind computer you got?
Posted on Mar 06, 2008
  • Patrick Michaels
    Patrick Michaels Mar 06, 2008
    sheesh..you might consider waiting until an expert has more time, and is working with enough information, before rating it so low, eh?
  • Patrick Michaels
    not an issue, just a suggestion for the future.
    my bad for not asking for more information first.
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
I have (2) 1.1 USB ports that says they do not reconise the divice when i plug a divice in , and (1) 2.0 USB port that does nothing but when i go into device managment and check the USB controllers it...
I would suggest two things:
1) Get a different USB device and make sure it works in the ports.
2) Make sure the USB device you want to use is recongnized on another computer. (If possible)
If you have the Vista OS that came on a USB then it is not designed to work on 1.1 USB ports but it should work on the 2.0 port.
Apr 12, 2011 | Microsoft Windows Vista Home Premium with...
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
Vu point digital film/slide converter wont work when i plug the usb plug from the scanner into the computer a brief image appears across the screen aprox 3 secs (pic of scanner itself) then goes blank. I...
if this unit came from HSN (most did) then their specs show that it needs xp .. but their video claims it works for vista as well .. actually it depends on which model you have .. the FS-C1-VP . runs only on XP and below .. model FS-C1-Vp-BX2 .. has software to run on Vista and below .. Model FC-C520-VP-Bx2..runs on anything including vista and doesnt require software .. it just looks like a Mass Stroage Device when you plug it in .. these all look like a nice little machines for slides and negitives .. you might try unplugging the device .. reload the software (if you have any) ... then reattach the unit (to a different port) .. still problems then the USB port may be going into current limit .. you can try a different USB port (maybe one at the back of the computer) or better yet use a port expander with its own power supply .. make sure you dont have other USB devices that might be drawing current from the same USB source device (ok with the expander) .. if that doesnt get it going then if it came from HSN you can call their customer service number .. 800 933 2887 ... your item number would be 320-712 ... if the port expander or other suggestions fix it then let us know ..
it sounds like the unit is just drawing more current than your USB port can supply .. that happens a lot with large USB memory sticks (8gb or more) .. they are getting very close to or even exceeding the spec on the port .. some USB ports can do it others just shut down .. the external port expander with a power supply will almost always fix that problem and they dont cost much .. they are kind of nice also because you can put the expander ports within easy reach.
Dec 22, 2009 | VuPoint Cameras
I dont know were to start on downloading music to my ipod.I'm new to the computer
You need to download ITunes 9, it is a free download from www.apple.com. Once you have downloaded ITunes then you download your music into the program. After you have downloaded the music to ITunes(be sure to leave ITunes on), then you will plug in your Ipod cord into the bottom of the Ipod and the usb into a usb port on your computer. Your computer will recognize the Ipod and then you can transfer your music to it using ITunes. Good Luck, I hope this helped you Please Rate me, Thank You
Dec 19, 2009 | Apple iPod MA446LL/A MP3 Player
I pod nano not reconized by laptop with vista usb device not reconized code 10 appears
Which USB ports are you using? I just had this issue on a customer's computer and it turns out that a 5 port USB 2.0 hub they had installed in the pc wasn't functioning properly and so I would get a code 10 on their iPod nano. I plugged it into the onboard USB 1.0 ports and it installed correctly and synched. I would suggest trying other USB ports. If that doesn't work then go to Programs and Features in Control Panel and uninstall all apple products and then reboot and reinstall iTunes.
Oct 15, 2009 | Apple iPod nano 4th Generation
Ipod wont show up on itunes
When you have a high speed device like the ipod plugged into a non high speed usb hub, all that means is that it will take the ipod about twenty times longer to load up under itunes then it will using a high speed port. Try connecting the ipod to a different usb port and see if that one is a high speed port (if it is, it will most likely have 2.0 written beside it, and if it does not have it, when you plug it in, it will tell you if it is a non high speed usb port. The same message should pop up. Try all of the usb ports on your computer. You should have at least 1 high speed port.
Nov 08, 2008 | Apple iPod classic MP3 Player
Vista usb issue no inf file or corrupt
my only suggestion is that Windows Vista doesn't have the drivers for the USB port or it doesn't recognize it's there, I'd try downloading a driver off the internet, install it and see if that works
Hope this helps
Apr 01, 2008 | Computers & Internet
My itunes won't detect my ipod nano 4gb
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
