I broke my USB flash drive in half so that the part that enters the computer is separated from the chip, are there any repair services available?
I fixed my USB flash drive that broke in half and not only was I able to recover the information, but I could still use it if I wanted to. I took an old USB cable and cut off the end of it so there was the wire and the part to plug into the computer. I then separated the wires and soldered them to the flash drive and used electrical tape to reinforce it. You can also send your flash drive to a recovery service. Everyone told me there was no hope, but there was and I fixed it.
Posted on Jun 29, 2008
    Genius:
  • 3,587 Answers
Nope...time for a new one
Posted on Mar 06, 2008
How to Repair USB Flash Drives Broken, Unrecognized, Not Detected?
hi Jhon.
this is all i could find out.
Navigate Control Panel -> System -> Device Manager -> Disk drivers. 3. Find and select your USB device, right click and first choose "Uninstall" and then choose "Scan for hardware changes" to refresh the drivers. After all the operations, you will find USB not recognized issue is fixed and the flash drive is detected.24 Jun 2016
Repair & Recover USB Flash Drive not Recognized or Detected ...
https://www.easeus.com/resource/usb-flash-drive-not-recognized.html
How can I fix USB device not recognized?Method 4: Reinstall USB controllers.Select Start, then type device manager in the Search box, and then select Device Manager.Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...Once complete, restart your computer. Your USB controllers will automatically install.Error: "USB Device not recognized" when you try to access a USB ...https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...Search for: How can I fix USB device not recognized?
how to repair usb flash drive not recognized Google Search
Nov 30, 2017 | Electronics - Others
Black screen
Aspire notebooks are designed with personal entertainment in mind, but when your monitor blacks out after only a few minutes, it's somewhat difficult to be entertained. There are several potential causes, as well as a few different ways to fix this problem.
Possible Causes This problem can be caused by your laptop entering sleep mode, overheating, damaged or faulty components, an improperly seated monitor cable, low battery and/or screen resolution set outside the monitor's range. Sleep mode is the most likely culprit, particularly if you're using your laptop on battery power. b> Prevention/Solution Sleep mode settings are located under "Power Options" in the Control Panel. Damaged components can be replaced by Acer if you send your Aspire in for repair. Routine cleaning of the exhaust ports and upgrading the cooling system can fix overheating. Plug your laptop into a wall outlet via the adapter to see if low battery power is the problem. Boot into Safe Mode to adjust monitor resolution if you can't do so normally. b> Considerations Acer will typically provide service for damaged laptops under warranty, typically for only the cost of shipping. They can also repair computers which are no longer under warranty, though you'll have to pay the full price for servicing. You can open a ticket with the support department to try and determine what your problem is as well. A recall has been issued for Aspire models AS3410, AS3810T, AS3810TG, AS3810TZ and AS3810TZG made before September 15, 2009, because of a problem with the microphone cord that causes overheating if pressure is applied to the left palm rest.
http://support.acer.com/ acer sup
One of the most common ways to update (or "flash") the BIOS on a computer is by using a standard USB flash drive. If a new update is available for your BIOS, you'll need to flash it to update it. Short for "basic input and output system," the BIOS is the main program on your computer and will periodically need to be updated to ensure that your machine stays functioning the way you want it to. Though it is an incredibly important procedure, updating the BIOS from a USB flash drive won't take more than a couple of minutes to complete.
Insert the USB flash drive that you want to use to flash your BIOS into your computer. Download the update for your BIOS from the website of your BIOS manufacturer. (The manufacturer of your BIOS will be listed in the instruction manual that came with your computer.) Copy the BIOS update file onto your USB flash drive. At the same time, make a note of the exact name and extension of the update file. Do not remove the USB flash drive from your computer. Restart your computer. Press the key required by your computer to enter the BIOS. This key will be written down on the screen. Press this key immediately as your computer starts to turn itself on. Highlight "Boot" and then hit "Enter" to select it. Change the piece of hardware listed under "Primary Boot Device" to reflect your attached USB flash drive. This will tell your computer that you want to restart your computer and boot from the flash drive. Select "Save Changes and Exit" to restart your computer. Wait a few seconds for a command prompt to appear on your computer screen. The command prompt is an entirely black screen with a small line of white text that you can type on. Once the command prompt appears, type in the name of the BIOS update file on your USB flash drive. Then hit "Enter." Hit the "Y" keyboard key a single time to tell your computer that you want to update your BIOS. Your existing BIOS version will be upgraded (or "flashed") to the new version via the file on your USB flash drive. Do not remove the USB flash drive from your computer during this process. Remove the USB flash drive from your computer once the BIOS update process is finished. The update program will indicate when the process is finished. Your computer will automatically restart itself and your BIOS will be updated. Bios definition http://www.butterscotch.com/tutorial/What-Is-A-BIOS
Apr 11, 2013 | Acer Aspire One D257 Netbook
Cruzer flashdrive light doesn't light up
Use this USB drive on another working computer to check if your OS has any problem or not. If the drive is detected and you can access the infos stored in this drive, repair your OS, and if not, go to your nearest service center to avail a full replacement or repair.
Hope this helps, Mrityunjay.
Jun 26, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My Samsung SCH -a670 broke in half separating the screen from the body of the phone. I will power on. I need to transfer some really important locked pics from the phone. Help?
Good day!!!
if your cell phone have a direct USB features you can isert it directly on the computer to transfer some files...
if you don't have direct USB drive but your cell phone have a memory card you can insert it to the card reader and insert it to computer to transfer important files..
but if you don't have both unfortunately there's no other way rather than repair your c.p by replacing LCD screen..
Thank for using fixya and don't forget to rate my answer and write a testimony..
Jul 15, 2011 | Samsung SCH-a670
I took my Toshiba Laptop Satellite L305D-S5893, Model Part No.: PSLC0U 02601P to service center, They are saying there is video chipset problem and will have to change motherboard. I would like to know...
The video chip is part of the motherboard.
FixYa does not do repairs on any equipment. You need to take it to a computer repair shop to fit a replacement motherboard, provided there is one available.
In most cases it is better to put your money towards a new and better laptop, and may be a better alternative.
You can remove the hard disk from the Toshiba and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Apr 24, 2011 | Computers & Internet
My BD HP20 will not play most new Blu Ray disc. I understand it needs to be updated. Is there some thing I can buy to do the update ?
You need a USB flash drive (FAT format); in my experience even less than 1G drives are sufficient. Download the firmware update to your computer from the site:
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
(You'll need to fill in the drop down menus) The file is a .zip and must be extracted to the root directory of the USB drive. Then safely eject the drive from the computer (to ensure that the write step is finished). Plug the drive into the player (port marked Service) and go through the setup menus. Setup > Settings > Software Update (you need a password so it will ask you for one if not already set). Click Enter and the file on the drive will be compared to the current installed firmware. Then press Yes to install and wait for it to finish. If errors occur try removing and reinserting the drive. When done, remove the flash drive.
I hope this helps.
(some TV repair shops may have the flash drives available but you'd probably have to pay for a service call to get a technician and the drive.)
May 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Broken usb flash drive
The data is not destroyed, but it will be tricky to fix. I would suggest you find a local computer tech who is really good soldering tiny stuff. Or go to a Radio/TV repair shop. I think it will be possible to re-connect the wires and make it work.
Sep 29, 2009 | Computers & Internet
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
Laptop fell onto floor...now my memorex travel drive is broken...all college papers lost...help
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Nov 27, 2007 | Electronics - Others
Computers & Internet Logo
52 people viewed this question
Alun Cox
David Payne
David Payne
