Question about SanDisk Sansa E280 MP3 Player
Stuck in Sandisk image
Hi, My Sansa e280 was working fine, until I tried to turn it on while it was locked, I unlocked it and try to turn in on again, it did but the sandisk image stars to fade, and the it shows it again and then it fades until the screen is completetly black. Please Help me!!!
  • 8,596 Answers
Go to the Sansa website, and get the Sansa recovery tool:
http://www.sandisk.com/Retail/DriverDownloads.asp
Go ahead and do this, in case you have Windows Media Player 11 or the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Posted on Mar 18, 2008
E280 wont turn on, wheel only glows
For the e200 series player you can first try to RESET the player as next (solution 1):
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button. ( now the player should be off )
3. Press the Power/Menu button again to turn on the player, to see if the device is working normally again.
If the player still freezes after that, you can reload and update the lastest firmware (solution 2).
See next overview link:
http://kb.sandisk.com/app/answers/detail/a_id/4/kw/blue/r_id/101834
When needing more help, just add a comment in this same help request.
Jun 08, 2010 | SanDisk Sansa E280 MP3 Player
How can i reset my sandisk sansa e280?
SanDisk logo appears when stated then screen goes to grey and black. All appears to be frozen.
Nov 23, 2009 | SanDisk Sansa E280 MP3 Player
SanDisk Mp3:Turns on for about 15 seconds on the logo fades white
Try this from another user - let me know if it works:
ok so i called 1-866-sandisk and she told me how to fix it. you just flip the key lock at the top so you see orange, then hold down the record button. then you should get some sort of message on the screen. then you plug it in and under my computer a file should show up. you open it and make a folder in it called sansa.fwm (i think thats the right folder name, if not, try sansa.tmp or email me). then you unplug it and it should say formatting or something like that. once its done it should work.
Dec 29, 2008 | SanDisk Sansa E280 MP3 Player
Key Lock Sansa e280
on the top is a switch that says lock /unlock ......... switch to unlock
Dec 18, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 fatal failure - black screen, unrecognized by comp, won't restart..
1. turn sansa clip on
2. slide to "hold"
3. press and hold center button do NOT let go...
4. plug in the connector cable
5. wait until computer recognises Sansa device
6. let go of center button
7. drag n drop files and you are all set
if that doesnt work you will need to go to the sandisk website to update the firmware on your device..
let me know if you anymore questions..
Please rate accordingly
Thank you
Computerrep
Oct 31, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280
getting warm is normal I've never seen one get HOT, you can pull out the battery from these players very easey by removing 4 screws from the back of the player take it out for a minute and this should reset the player, if not you may need a new battery these are on Amazon for short money.
Oct 16, 2008 | SanDisk Sansa E280 MP3 Player
Load main image failed switch to recovery mode
follow the above steps but turn on the power button if nothing is happening. It's the only way I got my e280 to recovery mode
Sep 23, 2008 | SanDisk Sansa E280 MP3 Player
Sansa e280 media converter - unable to convert video
Try Deleting Some Of The Things You Don't Need And The Try To Put It In Again.
Jul 03, 2008 | SanDisk Sansa E280 MP3 Player
Please help me?
Heres something that worked for me....when I first got my e280 it worked fine then one day it just stopped.. After dealing with sansa customer support several times without any luck and trying everything else I could find in various forums, I came up with something that works for me....1st, if you are running vista, the device has to be turned of when you plug it in. If that does'nt work, try putting your sansa in lock mode...with it turned off plug it in to your pc and hit the power button until it turns off the push it again until it comes back on I did this several times and It worked and it continues to work....Good Luck.
Feb 29, 2008 | SanDisk Sansa Clip MP3 Player
Sansa e280 8gb white screen with black spot
It sounds like some data corruption.
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Oct 28, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
49 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
