Question about Maytag MDG16CS Gas Commercial Dryer
Find a manual
I am tryin to reset the timer on a Maytag MDG16CS Gas Dryer and can not find a manual anywhere can someone help me?
  • 2 more comments
  • Anonymous Feb 05, 2009
    My dryer's timer just keeps running as though it has received coins.
    Every one has just been pressing the start button and not paying ?
    How do I fix this I don not have any serving instruction's.
    Any help is appreciated.
    Maytag MDG16CSDWW
    My tenants don't bother putting in money because the dryer works just by touching the start button.
    The coin slide work's fine. I do not have installation instruction's or manual for time adjustment procedure.
    Any help appreciated.
    Maytag MDG16CSDWW Gas Commercial Dryer
  • lmbaca Feb 07, 2009
    Maytag dryer MDG16CS will not turn off. You can start the dryer just by hitting the start button and not putting in any money,
  • Anonymous Feb 10, 2009
    I have a Maytag MDG16CS gas commercial dryer and you can start it by pressing the start button without putting in any coins. You can hear the timer clicking the way it used to when you inserted coins. Now the timer just runs indefinitely so no coins are needed to start it. Does anyone know how to fix this? Any help would be greatly appreciated.
The coin operator timer consists of several small plastic gears. The teeth on the last plastic gear gets all chewed up so that the timer continues to run and unable to open the circuit which stops the dryer timer. Although the plastic gear probably costs pennies, your will need to order part number 33001275 torsion timer for about $75 - $110. Remove one screw & 3 clip-on wires - 15 min.
Posted on Mar 04, 2010
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
Dryer does not shut off
doesn't happen to often
1. timer could be broken (likely)
2. door lock another culprit
hydeparkappliancerepair.com
Oct 25, 2013 | Maytag MDG16CS Gas Commercial Dryer
Dryer won't shut off.
Will the timer advance in the NO HEAT mode? If it does advance you would know it has something to do with the temp alright but if it don't advance in No Heat then the timer motor is bad in my opinion. And it can fail by more than one way. Open winding OR stripped motor gear.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2012 | Maytag Dryers
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
HI, i was an appliance technician for 8 years but seemed to be stumped> i have a maytag coin op dryer but the model # and wiring diagram are missing. its an older style with the big idler. anyways,...
One way you could isolate the problem is to unplug the quick connect to the transformer and take the heat portion out of the equation ( just to see if the dryer starts on it own only). If the starting on it own goes away then you have it somewhere in that portion of the cycle. Probably 2 wires rubbing somewhere. Why do we need a dang transformer in a dryer? That would be the suspect to me. Never even seen this before. Hope you get a solution. Hope you post it.
Jan 18, 2011 | Maytag MDG16CS Gas Commercial Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Dryer does not heat.
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or ignitor. All of these parts are inexpensive and easy to test and replace.There is a free video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Apr 02, 2010 | Maytag MDG16CS Gas Commercial Dryer
Short drying time
probably will have to replace timer motor with one that has a longer run time.
Jul 07, 2009 | Maytag MDG16CS Gas Commercial Dryer
Maytag MDG16CSBWW heating problem
I have a Miele Novotronic T560C. The tumble drier is working fine except the air circulating is cold - it does not heat up at all. What could the possible reason for this and/or solution?
Oct 05, 2008 | Maytag MDG16CS Gas Commercial Dryer
Maytag MDG16CS Gas Commercial Dryer Logo
472 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
