FixYa.com
Tags:
Microsoft Windows XP Professional
Computer restarts randomly with blue screen. How... (by 2 users)
posted by emilmb on Mar 06, 2008
Problem:
My computer shuts down with a blue screen. Does it randomly. And reboots. Too fast to read the blue screen message.
I have:
Windows XP
EVGA 512-P3-N801-AR GeForce 8800GT 512MB 256-bit GDDR3 PCI Express
ASUS M2N32-SLI Deluxe Wireless Edition AM2 NVIDIA nForce 590 SLI MCP ATX AMD Motherboard
AMD Athlon 64 X2 6000 Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000CZBOX
G.SKILL 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel
Western Digital Caviar SE16 WD5000AAKS 500GB
600 Power supply
What can I do to fix it?
Comment by emilmb, posted on Mar 06, 2008
I will check later since I am not at home but I believe its not a virus. I just put the computer together and it started doing it right away. does it once a day maybe 2 times. I believe its hardware problem but cant figure out what is causing it. I already changed the video card once. I have not updated any drivers for anything except the video card and what the windows does automatically. Could it from some driver?
What is the purpose of "Step3 : Cleasr CMOS"?
C
an any of this mess up my hard drive or delete anything from it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by rakeshrsc, posted on Mar 21, 2008
MY COMPUTER STARTS AUTOMATICALY WITH THE BLUE SCREEN
Clarification Request
by ser71, posted on Mar 06, 2008
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N32-SLI%20Deluxe
here i enclosed the driver for your mainboard.
Sergio
what video card have you put
see if you have a virus check with nod32 3.0 www.nod32.com
Sergio
Solution #1
posted on May 17, 2008
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
yep i have the same problem, the computer randomly goes to the blue screen. i worked out in the end that one of my RAM sticks were faulty, so if you have 2 sticks, try it with one and if it still does it then try the other..
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
ser71
Rank:Guru Guru
Rating: 85%, 322 votes
Step1 :
Turn off the system power and unplug the power cord. Remove all PnP cards (Plug and Play) and cables including VGA, IDE, FDD, COM, USB, and external printer cable.
Step2 :
Confirm CPU and DRAM is inserted properly
Step3 :
Cleasr CMOS
(Please refer to motherboard user manual for jumper setting in clearing CMOS
) Step4 :
Plug the VGA card back to the system and also re-connect your monitor, mouse and keyboard. (connect ATX 20Pin cable to the mainboard. P4/K8 system will need to use ATX 12V 4Pin)
Step5 :
Turn on the power and make sure CPU, power supply and CPU fan is functioning.
Step1 :
Switch on the system. Hold down DEL key to enter BIOS Setup Menu.
Step2 :
Confirm date setting.
Step3 :
Check CPU speed setting and other boot up peripheral settings.
Step4 :
Hold down F5 to enter BIOS Setup Default. Hold down F10 to save and exit BIOS Menu and reboot PC.
Step5 :
Check whether the system will boot up properly.
Comment by ser71, posted on Mar 06, 2008
relax, read the manual, and see it. For security make a copy or your data.
Sergio
Solution #3
Not Rated (0)
gildonps
Rank:Master Master
Rating: 83%, 18 votes
It is possible that one of the ram sticks is faulty (though unlikely). I would insert one stick at a time, and see if that has any effect. Otherwise, it's most likely a motherboard issue. Since it's a fresh install, it's doubtful that it is software related.
Can you Help with these Operating Systems problems?
Operating Systems
atm s\w using java applet
i need to know how to program... Answer This...
Operating Systems
Blue screen in Vista
When I receive GPS data by a... Answer This...
Operating Systems
how can i download a4tech...
how to download a4tech pc... Answer This...
Operating Systems
panini cards
when are the new coca cola... Answer This...
Set up a DNS (domain name...
Can anyone reccomend a free DNS... Answer This...
Repair Service
Find Operating System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
