Question about Dyson DC18 all floors Bagless Upright Cyclonic Vacuum
Brushes won't turn remain motionless as if cleaning hard floors even though button depressed could it be a problem with the brushes or button still under guarantee
  • 1 more comment
  • Anonymous Apr 04, 2008
    DC 18 All floors anti allergy. Brushes not turning. Tried the brush on/off switch with no difference. Seem to remember a re-set button somewhere near the cleaner head. Anyone with clues?
  • lkessler Apr 05, 2008
    I also have the Dyson DC18 & have had it for @ 6 months. Just this past week, the brushes will not turn. HELP - luankessler@suddenlink.net
  • jzemsky Mar 10, 2009
    Is there any diagram or picture showing exactly where this reset button is?
There is a re-set button located on the brush head on the left side as viewed if you are standing directly behind the vacuum cleaner. It is black in color and is recessed slightly into the cover of the brush cover. It is round and about the size of the head of a country match and sticks up about 1/2 inch. Just press it to reset. Also, don't forget to press the grey on-off brush switch located beside the red on-off which is located near the top of the handle. Hope this information solves your problem. jawebb3@suddenlink.net
Posted on Jul 12, 2008
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Dec 31, 2016 | Vacuums
Is there a more efficient way to clean the brush assembly on the max extract dual v other than running the assembly under water? The bristles are loaded with carpet fuzz and remains of doggy doo
Following is the procedure for removing the brushes.
  • Your cleaner is equipped with removable brushes. Follow these directions for changing brush assemblies or for easy cleaning. How to Remove To prevent possible leaking, remove Clean Water Tank and Dirty Water Tank. Set tanks aside. With handle in upright position, tilt cleaner back until handle rests on the floor. 5.3 Grab brush assembly and pull firmly.
  • The brushes can be cleaned under running water. ! CAUTION ! To reduce the risk of injury from moving parts, unplug cleaner before servicing.
See page 17 of the link manual for the details
http://hoover.com/file/594
Dec 10, 2015 | Vacuums
Make brushes turn - band is intact but not turning the brushes
Hi there, it's Jack at Dyson.
Are you able to confirm whether your DC07 includes the brush control feature or not? The brush control would be a round dial on the cleaner head which allows you to turn off the brush bar when cleaning hard floors or delicate rugs.
If your DC07 does include brush control, make sure that when the vacuum cleaner is turned on and reclined, the brush control is set to 'Carpets'. The brush bar will never rotate when the brush control is set to 'Hard floors', or when the machine is standing in the upright position.
If you're confident your machine is already set correctly but the brush bar is still not rotating, or if your DC07 is a version which doesn't include the brush control feature, we'd appreciate the opportunity to provide further assistance.
I'd encourage you to give the Dyson Customer Helpline a call when you have your DC07 easily to hand so we can take you though some simple troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 03, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Our DC41 is impossible to push on carpet. Is there an adjustment to do? Almost like there is too much suction.
See if the following information can help.
CARPETS OR HARD FLOORS
• The brush bar will always default to 'ON' (spinning) each time you switch the
appliance 'ON' and recline it for cleaning.
• The brush bar will not rotate when the appliance is upright.
• To switch the brush bar 'OFF' (e.g. for delicate rugs and hard floors):
- switch the appliance 'ON'
- recline the appliance
- press the brush bar 'ON/OFF' button - the brush bar will stop spinning.
• The brush bar will automatically stop if it becomes obstructed. See 'Brush bar -
clearing obstructions'.
• Before vacuuming your flooring, rugs and carpets, check the manufacturer's
recommended cleaning instructions.
• Some carpets may fuzz if a rotating brush bar is used when vacuuming. If this
happens, we recommend vacuuming in 'hard floor' mode and consulting with
the flooring manufacturer.
• The brush bar on the appliance may damage some carpet types. If you are
unsure, turn 'OFF' the brush bar.
Dec 31, 2014 | Dyson Bagless Upright Vacuum DC41 Animal
Dyson dc33 brush won't turn but belt not broken
DC33 is suitable for cleaning hard and carpeted floors. It includes a brush control system which allows you to shut the brush bar off when cleaning hard floor surfaces. It's worth checking that the brush control is set correctly - it's possible it may have been inadvertently set to 'Hard floors'. For the brush bar to rotate, it must be set to 'Carpets':
It's also important to note that the brush bar will not rotate when the vacuum is standing upright, so make sure you recline it into the normal vacuuming position before testing it.
If this doesn't resolve the issue, please turn off and unplug the machine, then check that there are no obstructions in the cleaner head which could be jamming the brush bar. Remove any threads or hair around the brush bar, as these can affect the performance.
If you'd like further advice from our experts after you've given this a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). We can take you through some diagnostic checks to determine what may be causing the issue. If a repair or replacement part is needed, we can also confirm if this is covered under warranty.
Jun 05, 2014 | Dyson DC33 Bagged Upright Vacuum
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
The bare floor/carpet switch moves on it's own from bare floor to carpet all the time.
I'm sorry to hear you're having difficulties with your DC07. When you have your brush control set to 'Carpets', the brushbar should run when the cleaner is reclined into the vacuuming position, and shut off when you stand the cleaner upright. When you have the brush control set to 'Hard floors', it should remain in the off position until you change it manually back to 'Carpets'.
If it won't stay in the 'Hard floors' position during use, it's probably best if you get in touch with us directly so we can determine if there's a fault, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 22, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Dyson DC18 all floors Bagless Upright Cyclonic Vacuum Logo
457 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
