2003 Volkswagen Passat Logo
Posted on Mar 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
100,000 miles Oil light came on and engine stoped, is it worth rebuilding engine
Martin Bergin
Level 2:
New Friend:
  • Expert 133 Answers
  • Posted on Mar 07, 2010
Martin Bergin
Expert
Level 2:
New Friend:
Answers
133
Questions
0
Helped
55393
Points
391
If your engine is damaged as a result of oil starvation then its possibly not worth repairing the the engine.But what is worth doing is getting a second hand unit and fitting it in.If the crank is damaged then the engine is done for.
1helpful
2answers
Where is the oil pump on a 318,1992 dodge ram 1500
Inside the oil pan. Not an easy job. Just a note... Probably not the pump. Probably is the main and rod bearings on the crankshaft. Pull the engine. If really high miles rebuild the engine or replace it. If low miles (like 100,000), replace the crank and bearings. Unless a bearing has spun. You would know because there would be a constant knocking in the engine lower end.
1helpful
2answers
After vehicle has warmed, the oil light comes on under 1100 rpms . rev the engine the light goes off
You can't trust the light sensor, so you need to get a mechanical gauge. A cheap capillary tube one is only $10.
You should also change oil.
If the engine has over 100,000 miles, you could consider 20W-50 oil.
You could also have a problem with fuel or ignition, causing oil dillution.
Does it look too thin or smell like gas?
It could also be the oil pump is bad, but that is not normally worth trying.
The number of miles on the engine would help.
But low idle oil pressure is not that important.
2helpful
My jeep wrangler just passed 100,000 miles, what service does it need?
Here is the basic maintenance list for your Jeep:
~ Inspect lights and check tire pressure at least monthly or before & after each trail ride
~ Oil & filter change, chassis lubrication, differential and transfer-case fluids every 3,000 to 5,000 miles or 3 to 4 months - if you have recently crossed through water deep enough to submerge the centre of your hubs, replace the differential fluids as a precaution
~ Underhood belt and hose inspection every 3,000 to 5,000 miles or 3 to 4 months (every oil change)
~ Tire rotation and wheel balancing every 6,000 miles or every other oil change - driving offroad can knock wheel weights off a wheel, so you may need to have this done more frequently
~ Brake inspection every 6,000 miles or every other oil change - if you have rum brakes in the rear, ensure they are cleaned after each trail ride where you encountered deep mud/snow
~ Replace air filter every 12,000 to 24,000 miles or as indicated by inspection - dusty trails can shorten these intervals dramatically
~ Replace fuel filter every 24,000 to 100,000 miles
~ Automatic transmission service every 24,000 to 100,000 miles
~ Wheel alignment check every 12,000 to 24,000 miles or as indicated by tire wear - offroad driving can knock wheels out of alignment, so budget for an alignment every 3 months, then watch tread wear to see if it's needed
~ Cooling system flush and refill every 40,000 to 100,000 miles
~ Belt and hose replacement every 60,000 to 100,000 miles or 5 to 8 years
~ Engine timing belt replacement every 60,000 to 100,000 miles (when equipped) or 5 to 8 years
~ Air conditioning performance check annually, usually in the spring - be sure to run your A/C during the winter for brief period to ensure all hoses and valves stay lubricated and operable
2helpful
2answers
How much oil usage is normal?
1 quart every 2000 miles. Not all cars are created equal. The same model may burn alot less or even more.
1helpful
2answers
When should the timing belt be changed on a saab vector 1.9 Tid
Standard Answer for Timing Belts/Chains: 100,000 to 120,000 miles is when the Timing Belts/Chains start malfunctioning or failing. Some people want to go ahead and change them before malfunctions/failures happen.
I just replaced mine on 2002 Dodge Grand Caravan which just turned 100K. Most Timing Belt/Chain failures will cause more costly engine damage when these fail, including a need to replace/rebuild an entire engine.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
2helpful
What service(s) does a 2004 rav4 need at 100,000 miles?
This is Toyota's scheduled maintenance for the RAV4 at 100,000 miles...
Replace engine oil and oil filter 1
Rotate tires
Replace engine coolant 2
Visually inspect brake linings/drums and brake pads/discs
Applicable Footnotes:
1) Reset the oil replacement reminder (“MAINT REQD”) light after replacing engine oil, if vehicle is equipped with this light.
2) Initial replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter. Refer to "Engine Coolant" in the "Explanation of Maintenance Items" section in the back of this guide for more information.
2helpful
What is the recommended service for 2004 chevy
Service your cooling system every 5 years or 150,000 miles. The GM Dex Cool has a life of 5 years or 150,000 miles which ever comes first. Replace the thermostat also and buy the fail safe thermostat, it cost a bit more but worth it.
Service the engine (spark plugs and wire) every 100,000 miles or till engine management prompt attention. (service engine light DTC code)
Service the transmission every 3 years or 60,000 miles, replace the transmission oil and filter. Transfer case fluid and differential fluid.
Service the engine oil and filter every 6 months or 3,000 miles. Lube Chassis
Service the air filter and cabin air filter, wiper blades every 15,000 miles or once a year.
1helpful
The check engine light came on and the RPM needle
If depends on the milage of the car, some lights come on after 100,000 miles just to remind you that maintanace is require but is good idea to run the car thru a scanner to be sure.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
