Buttons my arrow button pointing left has fallan off. i have the button and two plastic bits and they wont go back on?
    Genius:
  • 3,587 Answers
Sounds like it's time for a new keyboard.
Posted on Mar 06, 2008
Where is the refresh button on my keyboard
It's right next to the 'any' key.
Generally when an instruction refers to the 'refresh' button, it is referring to the icon on the screen for your browser - it's usually a little picture in the top right of your screen depicting an arrow bent into a circle. Typically there are three simple browser control buttons together up there: the "back" button, which is an arrow pointing left and which takes you back to the previous page. The 'forward' button, which is an arrow pointing right and which takes you on to the next page after you have used the 'back' button. And the 'refresh' button, which is an arrow shaped in a circle and which tells the computer to go back to the internet and reload the current page.
A common purpose for using the 'refresh' might be when watching an auction item on e-bay. Your screen will not dynamically update, meaning that when others bid on an item, you won't see the activity until you refresh that page.
Aug 14, 2014 | Dell Computers & Internet
Tip
This doesn't seem to be working for me. The BACK button (single arrow pointing...
I selected the progressive botton on the menu and locked the whole System, please gime some tips so that i can solve this problem
on Jul 07, 2008 | Sony RDR-VX515 DVD Recorder/VCR
Change code combination
Setting the Combination
1. Remove the key holder from the KeySafe by pressing the RESET button, followed by the OPEN button. Pull down on the key holder from the bottom of the KeySafe
2. Remove the bracket. Press the Release tab on the bracket and slide the KeySafe upward until it is free of the bracket.
3. Remove the plastic card attached to the bracket. You will see ten numbered buttons with arrows. These numbers correspond to the numbered buttons on the front of the KeySafe. An up arrow indicates that the button is not selected, a down arrow indicates that the button
is selected as part of the combination.
4. Using the screwdriver tip on the plastic card, apply light pressure
to rotate the arrows on the buttons you've selected for your combination a half-turn to the downward position until it snaps into place. Caution: The arrows must either point up or down, with downward arrows representing the numbers in your combination. If any arrow is pointing left, right, or is not fully seated when turned downward, the combination will not work. Improperly setting the combination is not covered under the warranty.
5. Return the plastic card to the bracket for future use
Mar 10, 2014 | GE AccessPoint Digital KeySafe 001847
One button is not functioning(back button)
There is a free app called Button Savior. It will give you virtual buttons on your touch screen. There will be a little arrow you tap & they slide out (but you can see through them). The "back" is an arrow pointing to the left.
Nov 10, 2013 | Cell Phones
My 2011 Dodge Journey shows "Back" with an arrow pointing to the left in the middle control panel. What does this mean?
The center panel allows you to access tons of information. The icon your describing means that if you push the "back" button on your steering wheel, you will go to the main menu. All the menus are controlled by the arrow buttons on the wheel.
Feb 06, 2013 | 2011 Dodge Journey
How do I change the date and time on 966 printer
On the Printer's "Main Menu" press the arrow pointing "down" to select the "Setup" option, which you will see just below the "scan" option. When you see the "Setup" option press the round "check mark" button, which will change your screen and you will see several more options. Press the arrow pointing "down" to highlight the option that says "Change Printer Default Settings" and then press the round "check mark" button. Now you can make the necessary changes to the time and date. To do this press the arrow that point to the "right" which is right next to the round "check mark" button. Select the correct time and then select the correct date. When finished simply press the "curved arrow" BACK button which is to the left of the "left arrow" and round "check mark" buttons. I hope I explained this good enough for you guys to be able to correct your printer's time and date.
Nov 13, 2011 | Dell 966 All-In-One InkJet Printer
How do I view video
First set the camera to Playback mode. On the back of the camera there are two circular buttons. Looking at the top circular button, the bottom option is a right-pointing arrow. Press that arrow.
The last thing you photographed or recorded will display on the screen. If this is not what you are looking for, you will need to navigate to the correct item. To do this, use the bottom circular button that has both a left-pointing arrow and a right-pointing arrow. Use the left-pointing arrow to go back through your images/recordings.
The video recording should play automatically and repeat when completed.
May 04, 2011 | Fuji FinePix Z10fd Digital Camera
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
How to print a usage page for HP color laserjet CP2025n
You can print usage page as follows via front control panel on the printer itself.
  1. Control-panel display: The display provides information about the product. Use the menus on the display to establish product settings.
  2. Back arrow ( ) button: Use this button for the following actions:
    • Exit the control-panel menus.
    • Scroll back to a previous menu in a submenu list.
    • Scroll back to a previous menu item in a submenu list (without saving changes to the menu item).
  3. Left arrow ( ) button: Use this button to navigate through the menus or to decrease a value that appears on the display.
  4. OK button: Press the OK button for the following actions:
    • Open the control-panel menus.
    • Open a submenu displayed on the control-panel display.
    • Select a menu item.
    • Clear some errors.
    • Begin a print job in response to a control-panel prompt (for example, when the message [OK] to print appears on the control-panel display).
  5. Right arrow ( ) button: Use this button to navigate through the menus or to increase a value that appears on the display.
  6. Cancel Job (X) button: Press this button to cancel a print job whenever the attention light is blinking or to exit the controlpanel
    menus.
Now follow these points to print th required page:
  1. Press OK to open the menus.
  2. Press the Left arrow ( ) or Right arrow ( ) button to navigate to Reports, and then press OK.
  3. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the reports, and then press
  4. OK to print a report.
  5. Press X to exit the menus.
The following information pages are available:
  • Demo page
  • Menu structure
  • Configuration page
  • Supplies status page
  • Network configuration page
  • Usage report
  • PCL font list
  • PS font list
  • PCL6 font list
  • Color usage report
  • Service report
  • Diagnostics report
SOURCE
Oct 25, 2010 | Computers & Internet
HP 4300n prints off the right margin
You possiblely have a font set wrong in your printer. Push the green check button, arrow down to printing, push the check button again, arrow down to PCL and push the green check button again. Arrow down to Font Source, push check button again and check setting, should be internal. Push the left arrow button till you get back to Font Source and down arrow key to Font Number, all ours are set to 3. Left arrow key back to Font Number and down arrow again to Font Point Size, all of ours are set to 12.00. To get back to ready, uset the left arrow key.
If this is all correct, then it has to be in your software.
Mar 05, 2009 | HP LaserJet 4300n Printer
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
