Question about GE JKP15 Electric Single Oven
Bottom burner not working
Replaced bottom burner...oven still not working...looking for next step.
  • Tony48 Mar 10, 2008
    Thanks spidy I will try that..
  • 20 Answers
Check the fuses in oven also check cartridge fuses in fuse panel also look for a burn wire.
Posted on Mar 09, 2008
Oven gets warm but not hot?
This could be a thermostat issue or a burner issue. Most ovens have a top and bottom burner, if one of them is not working, the oven may not reach or stay at the right temperature. You should be able to get a replacement at home stores that sell appliances or order one online. They are fairly easy to replace. You may have to remove a couple of screws but otherwise they pop out and pop in. You can test the burners by turning the oven on bake and a few minutes later open the oven to see if the bottom burner is red, if not it may be burnt out. You can set the oven to broil and after a few minutes, look at the top burner, if it's not red it's likely burnt out. If both burners seem to be working, it is likely a thermostat issue. I haven't replaced one of them before, but you should be able to find instructions on youtube to determine if it is something you are comfortable replacing on your on.
Aug 11, 2017 | Ovens
GE JGBP33 gas oven will not light. Burners and brioler will light. When trying to ignite oven, igniter will not glow, and I see no change in voltage accross igniter contacts. What's next step to...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 27, 2011 | GE Ovens
My magic chef rv range will not light the burners with the ignitor. I replaced the ignitor at the control due to the wire prong being broken off. It worked prior to the wire prong breaking off. What do...
hope this helps a little...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/15-104--/Magic-Chef-Stove-burner-won-t-light
Jan 14, 2018 | Magic Chef Ovens
Oven "bake" burner wont ignite on a gas oven.
heatman101
Dec 27, 2010 | Whirlpool Ovens
Oven won't light. Broiler will ignite and
I don't know how new or what brand your oven is, but chances are you have a bad igniter the bottom burner. It is a small element attached to the burner that should glow red hot when you turn your oven on to ignite the gas. This is the most commment setup and problem. You will have to remove the bottom tray (there are usully 2 finger screws holding it in) to see it. It should look something like this:
http://www.theignitorstore.com/product/306602/range_oven_igniters
If you turn the oven on and nothing happens, turn it back off. You can disconnect the igniter, connect a multimeter set to volts AC, turn back on and check for voltage (120 AC) Don't let any bare wire ends touch the oven or you. If you have power there, its the igniter.
Just get the model number off your oven to look up the proper replacement. Replaces with 2 screws. Make sure it mounts close to the burner. It should only take a couple seconds after you hear the gas turn on to ignite. Hope this helps.
Jan 02, 2010 | Ovens
Bottom burner for maytag gas oven will not light. The broiler will turn on and heat, but not the bottom burner.
will have to replace the oven ignitor part #120000035 / this will correct burner problem / mm
Dec 08, 2009 | Ovens
The oven burner will not ignite.
Because the glowbar is glowing does not necessarily make it good.
Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
If the glowbar reads 3 amps or less,replace the glowbar ignitor.
If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
Check all the wire connections for the gas valve.
If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
Dec 01, 2009 | Amana Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
9" burner is not working
First, examine the 9 inch ring that is not heating. Look for any rough spots, which would indicate that the 9 inch coil is burnt out. (which would require burner replacement) If you find none, next check the wires where they attach to the burner to see if one might have burned off. That would be the easiest and least expensive repair if you find that. Failing the first two steps, the next would be the 6,9,12 switch.
Oct 12, 2009 | Ovens
Gas oven not working. burners work. not
The holes may be plugged with residue. With the oven off! Try taking a paper clip and unplugging the whole. Make sure the ignitor next to the burner tube is secured and is not broken. These are under the bottom oven plate. Most models.
Sep 04, 2009 | Maytag Ovens
GE JKP15 Electric Single Oven Logo
91 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
