POWER ??? RED WARNING ON MY COMPUTER HAS COME ON THIS AFTERNOON ITS ON A ICON THAT IS A BATTERY WITH A PLUS AND MINUS ON IT WITH flash of lightning going though it
    Genius:
  • 3,587 Answers
Hmm...a laptop, right? that's a clear indication that you are on battery power, and perhaps your power device is really and truly unhappy.
Posted on Mar 06, 2008
Flash fires but does not illuminate the subject.
Do you perhaps have minus compensation dialled in on either the flash or your camera body?
Look on the camera for a small button with a lightning symbol and a plus minus beside it (+/-)
Normally you can make the flash output stronger (+) or weaker (-) depending upon the situation. Normally it should be left in the middle.
there may also be a similar button of the flash itself.
Hope this helps. if not then please let me know.
Mar 16, 2015 | Canon Speedlite 420EX TTL Flash
I have Equity Time Insta-Set Model 40018. I lost the directions about how to set it. How do I get the directions? Are they available online?
Model 40018: You do not need the 9-volt battery to operate this clock.
NO TIME DISPLAYED WHEN PLUGGED INTO AC POWER:
If the display is blank when plugged into the AC outlet, unplug from AC power and remove the Insta-Set battery (lithium button cell), then plug into AC power again and manually set the Time and Date.
  • HOUR: Press and hold the DST SET button for 7 seconds until the 12:00 flashes. Use the PLUS and MINUS buttons to set the Hour. Press and release the DST button to move to the Minutes.
  • MINUTES: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Minutes. Press and release the DST SET button to move to the Month.
  • MONTH:The Month will be flashing. Use the PLUS and MINUS buttons to set the Month. Press and release the DST SET button to move to the Date.
  • DATE: TheDate will be flashing. Use the PLUS and MINUS buttons to set the Date. Press and release the DST SET button to move to the Year.
  • YEAR: The Minutes will be flashing. Use the PLUS and MINUS buttons to set the Year. Press and release the DST SET button to secure the setting in the memory.
After completing the manual set for time and date, insert a fresh Insta-Set button cell battery and the settings will automatically be stored in the clock.
Jan 31, 2015 | Audio Players & Recorders
How to replace my battery without locking up my radio with theft deterrent
Obtain a temporary battery (12volt)and connect it across the terminals plus to plus and minus to minus this will ensure there is power available while you disconnect the old battery and replace with a new one,when the new battery has been installed remove the temp supply.
Len
Oct 14, 2014 | Cars & Trucks
How to change red blue and green color on monitor hp7540
Press the menu button on the monitor, should be the far left button...use the minus and plus buttons to scroll thru the menu. Select the function you want by pressing the far right button (not the power). The function you want is the one witht the temp icon and the letter "K". press the far right buttion again and use the the plus and minus buttons to adjust the level.
Hope that helps.
Tom Miller
Broadcast Engineering
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
How do i set the flash on my vivitar cam. model 8025
Touch the lightning bolt icon in the function area until the flash icon and the letter A appears on the left side of the display. This activates the automatic flash.
Touch the lightning bolt icon again until the letter A disappears. This forces the manual flash mode.
Touch the lightning bolt icon again until the eyeball appears on the left side of the display. This activates the red-eye reduction feature.
To turn off the flash function touch the lightning bolt icon repeatedly until the no-flash symbol (lighting bolt in a circle with a line through it) appears on the left.
This is all described in the manual.
Jan 23, 2010 | Vivitar ViviCam 8025 Digital Camera
IS THIS CAMERA WATERPROOF AND HO DO U TURN ON THE FLASLIGHT
No, the camera is not waterproof.
Touch the lightning bolt icon area until the flash icon appears on the left side of the display. This will activate the flash.
Touch the lightning bolt icon area again until the flash symbol appears on the LCD screen. This forces the flash function.
Touch the lightning bolt icon area again until the eyeball icon appears on the left. This activates the red-eye reduction mode.
To turn off the flash, touch the lightning bolt icon area again until the no-flash icon (lightning bolt inside a circle) appears on the left.
This is covered on pages 13-14 of the manual. If you've misplaced your manual, you can download one from the manufacturer's web site at http://vivitar.com
Jan 18, 2010 | Vivitar ViviCam 8025 Digital Camera
How do you use the flash on a vivicam 8025?
Jan 17, 2010 | Vivitar ViviCam 8025 Digital Camera
Flashing battery icon
The machine is telling you the battery is not charging or is otherwise no good.
The battery for this unit is subject to a recall, if it has part #OU091 or W1435. This recall started in October 08. Go to:
http://www.dellbatteryprogram.com/
for more info.
Alternatively, bring your power supply to a Radio Shack, and make sure it is putting out the requisite 19V DC power.
Jun 12, 2009 | Dell Inspiron 6000 Notebook
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
