Dvd player model v56l-5c. will not play dvds-when trying to load disc, just makes mechanical "chattering" noise then stops loading. keeps trying,etc. [plays cds ok.]region code is correct. please help bob.
  • 2 more comments
  • robert mcgillivray Mar 07, 2008
    what is causeing the mechanical juddering noise when the dvd disc is trying to load ? a cd disc loads ok, and plays fine.bob
  • robert mcgillivray Mar 08, 2008
    all my dvd disks are original [bought] bob
    thank you, i will try getting the laser readjusted asap. bob
    dvd disks are new [original]. bob
    President:
  • 1,944 Answers
Are your DVD discs original store bought or burnt?
Posted on Mar 07, 2008
  • Damen Wong
    Damen Wong Mar 09, 2008
    I hope for you that the realignment works...cause if not it means the laser unit will need to be replaced.
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 07, 2008
    laser might need realignment i think..
    if DVDs alone is not reading then this must be the problem.
    if any other internal fault means even the CDs wont read..
    thank you sir
    good luck
    dont forget to read the solutions
    thank you sir
    good luck
    dont forget to rate the solutions
    Sergeant:
  • 406 Answers
Try Another DVD media else Try Cleaning Lens , Else DVD is malfunctioning refer to service Engineer for servicing.
Posted on Mar 06, 2008
    Master:
  • 555 Answers
How old is this unit?
  • Matt Jurach
    Matt Jurach Mar 06, 2008
    The laser might need realignment, especially if the unit is old or has been moved frequently.
    It may still read conventional CDs since the laser tracks differently to read DVDs.
    It could just be a dirty laser, though. You can try a cleaning disc and see if you get better results.
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
My JVC HR-XVC27U plays some DVDs but not others. They have the correct codes, but it seems to not play the newer DVDs like Toy Story 3
see the causes and remedies and fix it: God bless you
Jul 20, 2012 | JVC HR-XVC27U DVD Player/VCR
My dvd player stopped loading dvds. It will say "loading" for a while before it just says "disc error". It's definitely not a problem with the dvds though, I've tried a few and they all...
This is a Laser Pickup Assembly issue, the pladder motor that the dvd sits on is not working and has become defective, the only solution is replaced the machine for a new one, not cost effective for repair.
Jan 05, 2011 | Toshiba SD-1800 DVD Player
My united will not play. when loading makes load noise, spins then stops. eather says no disc orun known. tryed a lot of dvds. did show that it was loading but that has stoped also
Sounds like a hardware problem.
This is typical when one one of the DVD mechanism (motor fails, laser can't track, etc).
Although you can try some sort of DVD cleaning disk, or better yet
if mechanically inclined you can open it up and clean the DVD head and motor mechanisms manually.
Search here, or on the web on the steps to open up and clean them.
If it's still under warranty, call manufacture technical or customer support for a possible replacement.
Jul 20, 2010 | iLO DVDR05 DVD Recorder
DVD tray makes noise when it rotates
This noise can be casued by two things:
1) The tray is not completely in the loaded position and the "clamper" is rubbing. Replace the loading belt and the loading sequence will complete and the noise should stop.
2) The "CD table" that is part of the spindle motor assembly has slipped a bit. This will make the CD/DVD ride too low and strike the lower tray support. This will require that the table be "re-aligned" to the proper height which may not be possible on your model without special measurement equipment. The height is critical to proper operation of the unit.
Try replacing the load belt first and report your results.
Thanks,
Dan
May 30, 2009 | Kenwood DV-605 Multi-disc DVD Player
DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
Mar 03, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Samsung dvd home cinema system ht-ds110 not playing dvds
My initial IDM-1731 tells me no disc every time i try to play dvd cd please help me
Jan 06, 2008 | Televison & Video
DVD Locks up
Sounds initially like your loading mechanism needs service.
Are your discs clean and free of debris? Have your tried a disc cleaner.
Apr 23, 2007 | LG LDA511 DVD Player
My DVD player wont read a disc
There are several things you can do to try and solve your problem: Make sure that the DVDs you try to play are encoded for the right region. Make sure that the transportation lock (usually a plastic screw on the bottom of the unit), is not engaged. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on.
Mar 20, 2006 | Panasonic DVD-S31S DVD Player
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
