Help!!!! My laptop won't boot I have Microsoft Windows Vista v2.0 Ultimate installed on one parition and DonCorp OS v3.5 on another what should I do?
  • 492 Answers
Do a restore on your windows OS
Posted on Mar 07, 2008
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
Downgrading from vista to xp ( I have disk ) on h p dv6500 dv6504au A M D turion64 x2 Can you help please.
You download GPARTED live cd, boot it usually by pressing the boot key at startup, select cd drive, delete the paritions on the hard drive, or if you want to keep you're vista, resize it, then once thats done, boot from the XP disc, and select the empty partition format it, then install to it. Done.
Sep 02, 2011 | Microsoft Windows Vista Ultimate Edition
I m lookin for installing dual boot with Vista ultimate n Windows 7, gotta dvd for both, any help??
If you wan to fresh install, here you can do ::
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD: Vista Ultimate
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
Format the drive by pressing L, and then create three partition , 100 GB for Vista Ultimate, 100 GB for Windows 7 and rest for data.
Hit enter and let os Load
After complete OS loading, system will restart and again you will see " Press any key to continue"
OS will boot and register it with microsft. create login and then remove OS DVD,
Insert the Windows 7 DVD
restrt the system, Hit enter when it says " enter any key to continue"
select new installation, point to the earlier created partition for windows 7 installation
proceed with same procedure.
after complete installation, when you restart the pc, you will find both the BOOT entries at booting.
do not forget to load device drivers on both the OS.
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
My os is japanese character
You can only change the language of Vista if you have Vista Ultimate
or Enterprise.
With Ultimate, you can download the language packs for free.
Just open Windows Update, choose "view available updates",
and check the language pack you want.
Afterwards, from Control Panel (categories view), just choose
"Change display language" under "Clock, Language and Region".
Pick your language, log off, log on, and done.
If you have another version of Vista other than those two,
such as Windows Vista Home Premium,
you'll need to purchase a "full version" of Windows
Vista in your desired language and perform a "clean install" or
install it on a separate partition or drive (dual-boot).
May 25, 2010 | Microsoft Windows Vista Ultimate Edition
Say some method to uninstall geniuvista os?
You planning to install other OS instead of Vista?? If no, you can go for a format. Put your OS cd in the drive and boot your lappy. Folow the on screen instructions to format your C: drive.
Thank you!
Apr 15, 2009 | Microsoft Windows Vista Ultimate Edition
Uninstallation of Windows Vista ultimate Edition
Just boot from the installation cd. when prompted to repair or don't repair choose don't repair on the next step you'll asked to format the hardisk or leave the current partition. if you dont have any important data I recommend to format your hardisk. Backup yaour data before installing
Mar 21, 2009 | Microsoft Windows Vista Ultimate Edition
I have Windows Vista Ultimate, my computer was running slow, so I decided to reinstall the OS. It boots with no problem and goes as far as setting up your computer. Then a window pops up stating windows...
Your missing the files that load the operating system. Put the vista disk back in, let it run and it will eventually ask if you want to setup or repair. Choose repair and then type "fixboot". That will fix your master boot record so the operating system can load.
Mar 08, 2009 | Microsoft Windows Vista Ultimate Edition
Unable boot vista ultimate (installed earlier) after installing new xps2
You have to reinstall vista bootloader.
Just insert vista dvd in the drive and boot from it.
Select startup repair and it will fix everything back to normal.
Jul 05, 2008 | Microsoft Windows Vista Ultimate Edition
Tv/media/volume buttons
it means formating the win but you have the cd of the vista then go had other wise don't do it
Jun 01, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
