Question about Cameras
Camera my memory card says 'card locked' and I am unable to delete any of the pictures or use the camera, could you tell me how I can solve this problem please. many thanks Sheila.
  • Beth C Apr 17, 2008
    On my camera it is reading Card Locked! I cannot do anything. Cannot delete either. Please Help!!!! I put new batteries in. Removed the memory card and put it back in......
There is a liitle switch at the side of the s.d. card try moving it this may help i hope so good luck the grease fanatic
Posted on Mar 06, 2008
  • 29 Answers
If your camera uses SD (Secure Digital) type memory cards, there is a small switch on the left side of the card.
Remove the card from the camera and use your nail to drag the switch towards the other direction, so it is unlocked.
Hope this helps.
How do i unlock the card on my exilim.casio camera
if you put the camera on view and scroll through them does it give you any options , such as save ,delete etc,etc.
Feb 27, 2015 | Casio Exilim Cameras
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to delete pictures in built-in memory, dmc-LZ7
connect your camera to a compter
click start click on computer you should see your camera click to open you should see your pictures on the sd card select the ones you want to delece right click delete
hope it helps
Apr 03, 2012 | Kingston 1GB Secure Digital Memory Card
I Have taken pictures with the camera , after it saves it keeps telling me photo error , im trying to recovery images i have taken , and they are unable to view and when i copy them to my pc , windows says...
Your pictures may be corrupted.You can recover those corrupted pictures with this
1. Do not save any new pictures into the memory card of your camera.
2. Insert the memory card into a card reader. Connect it with computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is Tenorshare Data Recovery (simply because i was using it and it worked)
http://www.any-data-recovery.com/product/datarecoverystandard.htm
4. Install and open the program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
How to Recover Deleted Pictures from Digital Camera's Memory Card?
Aug 22, 2011 | Vivitar ViviCam 5385 Digital Camera
Samsung TL210 When trying to delete a image in camera recieve a "file error" message and unable to delete.
Check your memory card for the lock. If it's not locked and you steel having the issue then try backup all you pictures and format the memory card using format utility in setup menu.
Mar 13, 2011 | Samsung DualView TL210 Digital Camera
I have a Kodak Easy Share C182 . I want to delete some pictures and it tells me to remove protection to delete, and it also tells me image is protected please tellmje stepby step how to clear this...
The most common cause for telling you that the card is locked is having the tiny slide switch on the side of the card in the wrong position.
- see photo below:
Set the lock slider to locked or unlocked.man-3ds-sdcardlockswitch-287-181.png
  • The down position will enable write-protection, locking the card.
  • The up position will unlock the card, enabling you to save and erase data on the card
kodak-easy-idhgrcvb3gwnj1x0htsxmiux-2-2.jpgthe tiny slider is labeled with "Lock"
SD memory card lock Nikon Knowledgebase
Dec 03, 2010 | Kodak Easyshare C182 12MP Digital Camera
Card locked unable to delete any pictures also unable to take any pictures
Check the memory card for a white sliding plastic lug usually found on the side.it slides to protect you from accidentally deleting images, it is very easy to move this on or off.
Aug 03, 2009 | Cameras
My DXG model 552 is locked?
Try pulling the memory card out of camera too see if you can take a picture with out the memory card in place.
If you can do this the memory card is locked. Look at the memory card and find small swith on the side. Look for the lock symbol and be sure the switch is not in the locked position. Move the switch as needed.
Put the card back in and try it. This should solve your problem
Aug 14, 2008 | DXG Technology DXG-552 Digital Camera
Memory card locked!
There is alittle slide on the memory card.
Take it out. Look for it. Depending what you have it may be yellow, look on the left. If it's down, slide up and it will be unlocked. :)
Apr 19, 2008 | Canon PowerShot A520 Digital Camera
Cameras Logo
186 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
