Question about Mitac Mio 168RS GPS Receiver
Error 608 I have a Pocket PC, Mio 168RS. Since recently I have not had any problems synching it with my desktop PC. When I try to synchronize I keep getting this message: "Communication Error: Cannot start communications with the desktop computer. Remote Networking could not start due to a critical error (Error 608). Please reconnect your device. If the problem persist, restart your device using the instructions provided by the manufacturer" I have checked the settings on both pocket PC and desktop but everything seems to be OK. Any idea how to fix this problem? Thank you in advance! Petrus
  • Anonymous Mar 29, 2009
    i need to open
  • 45 Answers
You must reinstall the software from your device. switch it off from the power button and then back on with the joystick pressed down.You will have a blue screen. Put inside one sd-card formatted in fat16 file system with the rom named as winceimg.bin ( you will find it on google).Choose winceimg by sd/mmc card by pressing joystick center. Wait untill on the display will write "restart your device". This will solve your problems
Posted on Apr 10, 2009
Mitac Mio DigiWalker 168, Pocket PC PDA w/ GPS
mijn probleem is dat ik deze pc/pda in het nederlands wil zetten hoe doe ik dat
Sep 09, 2008 | Mitac Mio 168RS GPS Receiver
I have Tomtom 5 Mitac Mio 168 Bundle, I can not charge it because there are some pins broken in the charger connection inside the handset.
If you cant put it in service , you can try to resolder only needed pins for charging. here is a link with pinout : http://pinouts.ru/PortableDevices/mitac_cable_pinout.shtml
Apr 21, 2008 | Mitac Mio 168RS GPS Receiver
Can u get the pda to read pdf files?
There is a special pocket pc version of acrobat reader . Go to the adobe web site
http://www.adobe.com/products/acrobat/readerforppc.html
Oct 13, 2007 | Mitac Mio 168RS GPS Receiver
Synch or move files
The Pocket PC 2002 software allows you to transfer files over to the MobilePro P300. Please look under "Synchronization" in the Getting Started Guide for details on your particular situation.
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Can't find drivers...
should work with active sync, let me know if you have any problems with it.
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
Sep 12, 2005 | HP Jornada 565 Pocket PC
Why does pocket mirror trawl through all items when synchronising a calendar
The HotSync software on the Mac was never designed to cope with the scenario where you synch with a PC elsewhere. It assumes that you are performing a recovery synchronization when it sees that the handheld synched elsewhere. The assumption with the Palm OS was always that you synched one computer to one PDA. With more propsperous times, the software has not yet evolved at Palm Source (not part of Palm Inc any longer.) With regards to PocketMirror, there is a setting to allow you to synch to more than one PC. The setting is buried deep in the PocketMirror settings for each of the four conduits. The setting allows PocketMirror to see more than one PC as your route to an Exchange server.
Sep 11, 2005 | Palm Zire 71 Handheld
Synchronization error
first try soft resetting your Ipaq, and restarting your PC.
Sep 11, 2005 | HP iPAQ H2215 Pocket PC
"Communications Error 608"
If you put the Toshiba Pocket PC e740 in your USB Cradle you may receive a "Communication Error 608". This is not a serious error, it is just a false setting in the ActiveSync Program. Please follow these steps below to correct this problem: "Tap" on start and choose the ActiveSync program Then "tap" on "Tools" and choose "Options" in the ActiveSync Program Check under "Enable synchronization when cradled using" to see if the setting is on "USB" If it is set on "Bluetooth", please change it to "USB". Now you can close the application window Important: Please remove the Pocket PC from the cradle and then return it to the cradle. This activates the new setting Important to note: This above described issue occurs if you "tap" accidently on the Bluetooth Icon in the Program Group or activate Bluetooth of any other reason, the ActiveSync Option will be set to "Bluetooth" instead of "USB". This setting will cause the "error 608" if you put in the Pocket PC e740 in the Cradle and start to synchronize over USB.
Sep 07, 2005 | Toshiba e310 Pocket PC
Microsoft Outlook data won't synch
In ActiveSybch there is an option of setting the priority of either the PC, the PDA or leaving the items unresolved. You can either change this of follow another route. With the device off the cradle delete the partnership WITHOUT deleting the partnership folder. Place the device on the cradle & let AS find the device & setup the partnership. Once setup remove the device & go to options & set all the required options. Replace the device & it should synchronise. If you still have problems please contact me directly through email.
Sep 06, 2005 | Casio Cassiopeia E-105 Pocket PC
Mitac Mio 168RS GPS Receiver Logo
535 people viewed this question
Top Mitac GPS Experts
Greg Cann
Greg Cann
TO Lady
Are you a Mitac GPS Expert? Answer questions, earn points and help others
