Indesit WIL 163
On/Off LED and Iron LED flash once washer has started programme. Tries to turn the drum but makes whining sound.
  • 30 Answers
Hi it sounds like your motor has packed up they normaly whine when they break down if it's a uk model a seconed hand motor is about 40/60 pounds a new one is about 130 pounds hpoe this helps
Posted on Mar 07, 2008
Have you checked the belt?
Indesit wil 163 lights flashing
I can't make sense of your heading.
May 06, 2012 | Washing Machines
Drum wont turn ,I think I over loaded it.Do I need a new belt ?
I took the back off and discovered the belt had come off rather than breaking .I put it back on making sure it lined up properly and the machine works fine now .
Dec 28, 2009 | Indesit W 123 Front Load Washer
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Selector knob on my Indesit Washing Machine WI 121 keeps turning & light flashes twice before light turns off. This happens approx 4 times in a whole turn of the knob. Indesit want £100 to come out to fix!...
Hi.
Sounds like you have faulty control module, which is quite expensive to replace.
Also the E.P.R.O.M would have to be replaced as well.
Probably cheaper to buy new washer.
Good luck.
Nov 18, 2008 | Indesit W 123 Front Load Washer
Indesit 1000 cycle starts but then lights flash
Check the filter which is under the white panel at the front of the machine(the filter is in the lower right hand corner). Unscrew the filter and remove it. Mine was blocked with loads of grease/limescale. I cleared it out and the machine is as good as new again. I cleared the system with half a packet of soda crystals put into the main drum (on its own without any washing in!) and did a wash at 90degrees. Its as good as new now. Good luck. CK
May 21, 2008 | Indesit W 123 Front Load Washer
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Washing Machines Logo
306 people viewed this question
Top Washing Machines Experts
