Question about Kogi l4ax 14.1" Flat Panel LCD Monitor
Kogi l4ax monitor (black screen)
Bought a new compaq presario pc with windows vista. When I turn the computer on the monitor will attempt to come on til we get to the windows then the screen goes blank. I can hook up my old HP pivilion M70 monitor and everything is fine.
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen went blank, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. You might go get technician to fix it. Hope this help!! If anything I can help you with, feel free let me know.
Thank you,
Tan
Posted on Mar 07, 2008
The issue is that I had an XP machine and I bought a brand new HP deskktop Windows 7 and as soon as I turned it on I got a message on my Kogi that I should change the settings to 1280 X1024. Since I did...
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Feb 03, 2011 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I have a Kogi l4ax monitor that I am trying to hook up to a Dell Dimension 7000. The monitor works on my dell dimension 4550. When I start the computer it shows the windos Xp screen for 2 seconds then...
Are you able to boot in SAFE MODE? since your monitor works on one PC, but not another, it could be your screen resolution settings in the OS on the 7000 - safe mode loads only basic windows components - and you should be able to get to the desktop and reset the resolution down to a size that suits the monitor you are using. Alternately, if you are not comfortable with uninstall tools or don't want to waste a day going into safe mode all day long to fix something which may not need attention, if you have access to a spare monitor you can try it on the 7000 and see if you get the same message at normal startup - if you don't - you can lower the resolution a tad once you get to the desktop, shut down as usual, hook the I4ax back up, reboot and see if it works. Either of these suggestions will only cost you a bit of your time - zero money and should have no negative impact on your OS or any associated hardware. This is a simple DIY deal and worth a try at least.
Dec 18, 2017 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Bottom toolbar cannot be seen on monitor
if you are implying the task bar, you can try to click on the bottom of the screen and drag upwards then right click on the task bar and lock it in place/
Mar 25, 2010 | Kogi l4ax 14.1" Flat Panel LCD Monitor
No input signal flashing, but computer is booting
We need to narrow down the problem first. Let make sure that it is not the problem with the monitor by hooking it up the other PC, or hook up PC to another monitor to see if you still get the same problem with new monitor attached to it. The VGA cable can be bad also.
Mar 20, 2010 | Kogi l4ax 14.1" Flat Panel LCD Monitor
My Compaq presario f572us notebook screen turns black upon normal startup. The screen does not turn black if I start-up in the safe mode. It only when i attempt to start windows normally. Everything loads...
i also have a compaq presario f572us that's been having similar problems. when i went onto the hp website i saw that apparently they've been having similar problems with this type of computer as they offer free repairs for 2 years after you bought it. you should probably check if this works for you too
Oct 23, 2009 | Compaq Presario F572US Notebook PC
Monitor
try checking lcd logic board.
Mar 01, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Grey screen
First, you need to eliminate the video card or the Kogi as the problem, which is quite easy to do by testing a known working monitor on the Matrox card.
Jan 26, 2008 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Kogi L4AX 14" LCD Monitor.
jim
my supply has the following specs.
LIEN CHANG
BSA-35-115
AC input- 110-240v 1A  47-63Hz
DC output 10-17v  3.5A
Nom. V 12v
Nom current 2.9A
output power 35A max.
With this you can likely find a universal "brick" that covers your needs
Jay
Oct 14, 2007 | Kogi l4ax 14.1" Flat Panel LCD Monitor
Kogi l4ax 14.1" Flat Panel LCD Monitor Logo
213 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
