Question about Toshiba Satellite M45-S265 Notebook
Laptop not powering on
THe laptop stop power on i bought a new adapter because i thought it was faulty but it still refuse to come on. I rest it down for a few months and tried again , this time it came on for one day.From that day onwards it never come on again.
  • casinova Mar 06, 2008
    i tried it without the battery and nothing happens
  • Israel Guerrero Aug 05, 2008
    I have the sane problem, I think my battery is dead, I bought a replacement AC adapter, but the laptop still don't turn on, Is this laptop require the battery to turn on?
    Genius:
  • 1,019 Answers
This can be several Things.
1:- certain laptops require the Battery to be present, and in good condition.
2:- You Should test That Your Charger is outputting the correct Voltage to the laptop. ** This can be tested by using a multimeter on the centre and outer pins, of the Power supply socket Jack. Should read between 13-24 Volts.
3:- check that the system isn,t in standby or sleep mode.
push and hold power button for between 5-30 seconds.
4:- jiggle the power lead at the back of the laptop, to determine that you do not have a loose connection, to the mainboard.
Hope this Solves Your Problem.
Mike @ Compurepair.
Posted on Mar 07, 2008
    Genius:
  • 3,587 Answers
Sounds like a dead battery to me, or a bad motherboard..try it without the battery i
Posted on Mar 06, 2008
  • Patrick Michaels
    Patrick Michaels Mar 06, 2008
    i'd say you have a dead motherboard..
Battery not charging at all
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 15, 2013 | Acer Aspire One D255-1549 Atom N550...
Battery not charging dell inspiron 630m
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new dell inspiron 630m battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
Apr 05, 2013 | Dell Inspiron 6400 Notebook
Dell d810 battery not charging
Instructions
Determine if the Dell Latitude D810 battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
Apr 02, 2013 | Computers & Internet
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
5
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Dell vostro 3500 shows battery connected but not charging and intermittently shoes no battery detected
Instructions
5
http://www.aurabuy.com/cheap-9-cell-battery-for-dell-vostro-3400-3500-3700-7fj92-04d3c-paypal.html
Mar 28, 2013 | Dell Vostro 3500 Laptop Computer (Intel...
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
On 9/11/12 I purchased a NEW battery for my Acer Aspire 3000. When the battery was installed at work the laptop worked for 5 hours at work. I shut it down n went home. Where it stopped working.
Sep 12, 2012 | Computers & Internet
My Acer Aspire 5630 laptop will not charge all the time, even though the charger is plugged into it with the green light indicating its working. Its charges every so often, then stop, and my computer shuts...
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem. The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Another suggestion is to remove the heatsink and apply new thermal paste or the motherboard may need replacing. Leave it to an expert if you are not familiar.
Hope this helps.
Jun 26, 2011 | Computers & Internet
I was using my laptop and it automatically powered down. I thought the battery was flat so plugged into the mains. When I switch on button nothing happens, there are no lights on. Green light on AC...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
If no change, the power adapter may be faulty and need replacement.
Or, unfortunately, your motherboard could be faulty.
Hope this helps.
Mar 18, 2011 | Computers & Internet
I have a panasonic toughbook cf-48. It was working and then all of a sudden it shut down and won't turn back on. I thought it was that the battery wasn't charging, so I bought a new battery. When I looked...
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 25, 2009 | Panasonic Toughbook 48 Notebook
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
