Question about GE DBXR463EBWW Electric Dryer
Drier wont start
Is there a thermal fuse or something of the sort that will prevent this drier to quit working when overheated. the outlet was clogged and killed the drier. i just need to know what i need to change. thanks
  • mamaw gee Jun 09, 2008
    I bought this dryer 1 year ago and it won't start at all. I have turned off the circuit breaker switch and turned it back on, I have unplugged the dryer from the wall and still nothing. I was wondering also if there was a fuse on the actual dryer that needs to be replaced.
    Model # DBXR463ED1WW
  • manic_mama70 Aug 19, 2008
    Our ge dryer was working just fine and then we had a brief power outage and the switch quit working. We were also wondering if there was some kind of fuse or switch that we need to fix to get the dryer going again???
  • 156 Answers
Yes there is a thermo fuse in the dryer eather on the element houseing are on the inside back by the houseing
Posted on Mar 06, 2008
Kenmore dryer overheating on airfluff
driers that over heat may have the lint filter blocked preventing free air flow
check / clean it regularly
Have an accredited electrician / service agent check ti out
Nov 04, 2015 | Kenmore Dryers
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Old kenmore gas dryer quit working, I believe it may have overheated, I emptied lint trap, let it cool for over an hour with door open, it still wont work
If it overheated there's a good chance a thermal fuse or cutoff went out. Unplug dryer and remove wires from each one, temporarily taping wires together and seeing if it will start when plugged back in.
Sep 22, 2011 | Kenmore Dryers
Unit stoped working and found filter was full of dust and fins on cooler was also dust cloged.I cleaned both and still won't start up
hi.
if the cooling fins blocked, it is quite possible that the unit has overheated and tripped the thermal fuse in the motor.
thermal fuse are built in to the motor to prevent overheating. some thermal fuses blow and the entire motor needs to be replaced, while others will reset themselves when the motor cools down.
as the fuse is in the centre of the motor they cannot be replaced and can take quite a few hours to cool down and reset themselves.
the only thing you can do is to leave the vacuum overnight and try it the following day to see if the thermal fuse has reset itself.
if the unit still does not work then you may have to get the motor replaced.
hope this helps
Jul 13, 2011 | Vacuums
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Dryer stopped working will not turn on was working fine we have power to the outlet is there a thermal fuse to replace
Some have a stop switch on the belt tensioner. If the belt breaks the switch prevents the drier from turning on. Door swich can also cause dryer not to run. Do you see any lights on? Is there any LED's lit up on the display?
Jan 17, 2011 | Maytag Dryers
Everything has gone of on my tumble dryer is there a reset button whirlpool 6th sense awz7814al
Try the thermal cutoff fuse... first check to make sure you have 220 power to outlet and not just a blown breaker. next check power at drier itself to make sure your cord is not bad.. if all is well, check door switch and make sure it clicks like it should.. Next, UNPLUG CORD FROM OUTLET!!!. pull back off drier, and locate thermal cutoff switch, located near bottom on the blower fan housing. locate the thermal cutoff fuse which is usually white in color approximately 2 inches long and narrow with two blue wires, remove and replace approximately $14.95 in Oklahoma. Replace and your back in business....
Dec 20, 2010 | Whirlpool Dryers
Is there a fuse in the hoover wind tunnel model 6425-920, the vacuum just shut off during operation and will not re start with the switch. What should I attempt? Thank you.
its the switch. order the switch from the company or your local vac shop. 2 to 4 screws on the handle. then go to were the hand tools are kept, there should be 4 screws. then splice the wires and put on the wire nuts and new switch and your in buiesness. ( check for a clog before repair )
Jul 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Ge Electric drier not working
water indicates vent issue as far as not starting there is a thermal fuse mounted to element housing it may be out also be sure door is fitting and shutting ok
Jul 23, 2008 | Dryers
Fuses
We have Kenmore Elec Dryer - Model # 8860293, 70 Series. Where is the thermal fuse located? Dryer starts and shuts off in less than 5 seconds.
lantzer@hotmail.com
Mar 08, 2008 | Kenmore 63942 Dryer
GE DBXR463EBWW Electric Dryer Logo
122 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
