Try performing a reset. To reset your ONE XL, use a straightened paper clip, or something similar, to push the reset button. The reset button is next to the memory card slot, on the bottom of your ONE XL. Then turn your ONE XL on.
You may also want to contact TomTom Customer Support for assistance. http://us.support.tomtom.com/app/answers/detail/a_id/6964
Your TomTom may have to be reset. According to the manual:
push the reset button. The reset button is next to the memory card slot on the
Remember, after a reset, your TomTom MAY take up to 20 seconds to start when using it for the first time.
Using cable data /charger port you can do charging both at system or in car under car charger option. those specifications placed in manual and normally lasts for 3 hours
plug the unit into your usb cable on your computer and let it charge for at least 2 hours, then try again.
if
that fails, the reset is on the bottom of your Xl (little pin hole) but
make sure remove the sd card and you have let it charge for at least 2
hours before trying to start or resetting the unit.
if that fails, the reset is on the bottom of your Xl (little pin hole) but make sure remove the sd card and you have let it charge for at least 2 hours before trying to start or resetting the unit.
If this helps you plz rate this. Thank you kindly.
If it is plugged into the car, you use the DC charger. You can charge it using the usb port on your computer as well. In the accessories section of tomtom.com you will find an ac adaptor as well that can be purchased to charge it to an electrical outlet.
You Can charge your Tomtom when you drive, or you can charge it with a USB port on your computer.
I don't think they come with a mains charger anymore?
