I have a kenmore elite oasis washer that seems like the drain cycle stays on to long and has a loud grinding type noise when draining. I am assuming the noise is comming from trying to drain nothing and the pump is gasping for water. any suggestions
I have the same thing going on you have to take the drain hose lose and you might have some change in the pump that is what was wrong with mine.
Posted on Mar 09, 2008
My Kenmore Elite Oasis Ht Top Load washer has a slow drip from the drain pipe. How to stop?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
Oct 23, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Elite Oasis HE washer model #27092600. It is making a loud noise before and during most of the spin cycle when it is trying to drain. What would cause this. I have had this machine since...
Mine was making a high pitch sound, thought a rock got under drum.... now it stopped yesterday full of water ... and won't spin or drain. What can I do here at home to fix it?
Apr 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
If the washer machine kenmore elite oasis he is draining water is it a water pump or draining pump?
The drain pump evacuates the water from the tub and down the drain pipe. There is only a solenoid valve assembly to let water into the washer.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis runs fine but wont go through spin cycle
Try replacing the motor coupler between the motor and pump three small pieces about 18.00 dollars at sears parts store.
Jan 13, 2009 | Kenmore 23822 Top Load Washer
Kenmore elite heavy duty top load washer
REMOVE 3 SCREWS FROM BOOTOM PANEL CLEANE OUT PUMP RESOLVES YOUR PROBLEM , GRINDING NOISE SOMETHIG STUCK IN PUMP WONT DRAIN,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
