Question about Samsung Digimax S800 Digital Camera
Card Locked My camera want let me do anything it say's cadr locked every time I try to take a picture.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
I have a 7303camera it says card locked how can i use it?
I think the USB card is locked. You can slide the card out and flip the little notch up then replace and try.
Jan 08, 2016 | Praktica Cameras
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
MEMORY CARD LOCKED
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures.
Dec 22, 2013 | Nikon D3000 Digital Camera
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
When you try to take pictures it says card locked
on most memory cards, there's a switch that prevents writing to the card. It's on the left edge. Make sure it's "up" (toward the connectors) and not down.
if that doesn't help, try a different memory card. If it still happens, then we know the problem exists with the camera and not the card.
Dec 31, 2008 | Polaroid i531 Digital Camera
Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Memory Card Locked
:'( i'm in the same situation right now! :(((( I want my pictires back! i don't know what to do!
Jan 04, 2008 | Canon PowerShot SD1000 Digital Camera
Canon a400
Card locked means that the tab on the edge of the SD card has been moved to the "locked" position. This prevents deleting or overwriting anything that is on the card, and also prevents any more images being added to the card. Move the little tab to the "unlocked" position.
Nov 05, 2007 | Photography
Memory card locked!??
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
Samsung Digimax S800 Digital Camera Logo
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
