Question about Epson - PowerLite S1+ Multimedia Projector
No image My projector is hooked up to a docucam only.  After being unplugged once it fails to recognize the signal.  All power/cables were disconnected and reconnected.  Still no signal.  I read the manual and looked at the dip switch, how should that look?  What else can I do?
  • 682 Answers
1-SWITCH YOUR PROJECTOR OFF.
2-CONNECT EVERYTHING AS NORMAL CONNECTION.
3-SWITCH DOCUCAMERA ON.
4-SWITCH YOUR PROJECTOR ON.
5-CONFIRM THAT INPUT OF PROJECTOR IN RIGHT INPUT TO CAMERA.
6- CONFIRM THAT CAMERA CABLE IS GOOD BY PLUGING IT IN VIDEO INPUT OF ANY TV.
Posted on Mar 24, 2008
  • mohamed eltoni
    mohamed eltoni Mar 24, 2008
    CHECK VIDEO INPUT IN CAMERA IN VIDEO IMAGER POSTION.
No image! My input signal is recognized, but nothing will display.
check laptop output settings my laptop uses f4 with the function key to switch the output mode your laptop may have a similar setting from Laptop only to Dual Screen to Composite screens.
Jul 08, 2015 | Christie RoadRunner L6 Multimedia...
Unable to play live tv from lap top to projector
Is it just the live tv or the laptop in general you are not getting a signal from? Using 15 pin VGA cable correct from laptop to projector?
When booted to projector, on laptop, select "FN" key and either F5, F7 or F8 depending on your laptop. Look for the monitor logo on the F keys. This is telling the computer that you have hooked up an additional external monitor (the projector). Once will send image to projector, twice will display on both, a third time will return to just image on laptop.
Jun 17, 2010 | Sanyo PLC-XU51 Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
Usb cable hooked up to projector but projector not getting signal
the usb is for control, not for image. you need a vga cable for that.
Sep 02, 2009 | Acer PD116 Multimedia Projector
HDMI port in back of Epson 7500UB projector gives ''broken'' image
Seems like the wires going to hdmi1 are bad inside the projector. I would see about getting a replacement.
Feb 28, 2017 | Epson PowerLite 3LCD Projector
Canon LV-S2 projector not work with component signal input
Try unplugging the projector. This seemingly works but I can't figure out WHY....
Mar 18, 2009 | Canon LV-S2 Multimedia Projector
Hy, having problem with to conect projektor to the computer Anybody can help
The projector should have a cable similar to the monitor cable that would normally be hooked into the computer. The cables work the same and the one coming from the projector will use the same port as the normal monitor cable. Make sure that there is a good connection on both ends -sometimes one or the other get moved and the connection is lost.
Once the cables are hooked up, the projector should be turned on. Normally the projector will soon begin a startup routine and will cause an image to be shown on the screen. You can focus the image during that time.
After the image goes away you should be able to display whatever you want from your computer's software.
Normal problems in doing this are: leaving the lens cap on the projector, having a burned out bulb - once the power is turned on for the projector, it should cause the bulb to come on. Some models have a power on switch and a display on switch that must both be pushed to make the bulb light up.
Hope this helps.
Dec 26, 2008 | ASK Proxima C160 Multimedia Projector
Dropped signal
Have you tried changing the display to clone the image?
Nov 23, 2007 | Dell 2300MP Multimedia Projector
Projector Image Problem
Hi There
Your Projector switches to a 16:9 ratio when hooked up to a Video signal and to a 4:3 Ration when hooked up to a PC signal.
You can manually change this in the Menu functions if this bothers you.
Simply go to Aspect Ratio in your Menu's subfolders and press left or right once you scrolled down to it.
Sep 21, 2007 | BenQ MP610 Multimedia Projector
Epson - PowerLite S1+ Multimedia Projector Logo
163 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
