Question about Cameras
Film will not automatically advance to next frame
  • iranwest Mar 06, 2008
    I have a 35mm camera[film] The will not automatically advance to the next frame. MINOLTIA freedom zoom 90ex.
    35mm MINOLTIA freedom zoom 90ex
  • 818 Answers
Http://www.amazon.com/Minolta-Freedom-Action-90-Camera/dp/B00004TJ7Q
please download the manual from here. and see if good for you
Sergio
Posted on Mar 06, 2008
    Genius:
  • 3,587 Answers
That's a mechanism issue inside the camera. Sounds like it's jammed or broken..is this a new issue?
    Master:
  • 555 Answers
Unfortunately, this indicates a failure of the film spool motor. And, as my wife recently found out, fixing that generally costs more than the camera itself did...
Any chance the camera is still under warranty?
    Guru:
  • 1,894 Answers
Hi dude
  • dewan nafees ahmed Mar 06, 2008
    what is the camera model and make?
    actually you do not have a film in a digi cam....
    can you tell about which film are you talking??
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
How do i advance the film to the next frame in my Nikon N65
The Nikon N65 has a built-in film advance (power winder) so all you need to do is take a photo and it should advance. If no, the film isn't loaded properly or the drive is broken.
May 07, 2014 | Nikon N65 35mm SLR Camera
How to load film
http://www.usa.canon.com/app/pdf/compact_film/Sure_Shot_Z135_manual.pdf
The link above will take you to a .PDF that is an owners manual for the Canon Sure Shot Z135
On page 14 it lists how to load film into the camera.
1. Slide the back cover downwards
2. Insert the film
- Make sure the film is positioned above the film guide
3. Pull the film tip across until it reaches the film tip marker
- Make sure the film is flat
4. Close the back cover
5. Turn the dial to (auto)
(Turn the power on)
the camera will automatically advance the film to the first frame.
6. "1" should be displayed on the frame counter
If this show zero there has been an issue, make sure you are using the proper film for the camera
Aug 24, 2011 | Canon Sure Shot Z135 35mm Point and Shoot...
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
My meter won't work even with new batteries?
I have Nikon EM myself and I have an issue with meter myself. First, the camera won't start metering unless your film counter is at 1 position. So, you have to advance couple of frames in order to have the camera start metering. Second, my unit will show metering information when I press the shutter half way IF I have not advanced the film to the next frame. As soon as I advance the film and ready to take the pic, the meter needle drops and won't show any information. This is caused by the aperture arm of the camera dropping a little bit from it's initial position as soon as you advance the frame. Funny thing is that the camera will continue to meter and make correct exposure, just without the information displayed.
Aug 06, 2009 | Nikon EM 35mm SLR Camera
Film not advancing fully
Are you sure that you have loaded the film properly?
Sometimes if you have not started the film so that the sprocket pulls the film correctly the film can aquire slack and the teeth of the sprocket may not be successfully pulling the film from the canister each time.
Sep 07, 2007 | Pentax ZX-50 35mm SLR Camera
Film Won't Advance After Shot is Taken
Do u want to move to the next frame without actually taking the snap?
Aug 29, 2007 | Bell & Howell PZ2000 35mm Point and Shoot...
Double Exposure The Easy Way????
Not all cameras can do this. The Nikon N8008, for example, allows you to specify the number of exposures for each frame. The N80, on the other hand, doesn't. You have to cancel the Multiple Exposure mode to advance to the next frame, then set M-E again.
Sep 08, 2006 | Nikon N80 35mm SLR Camera
Cameras Logo
54 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
