Question about Vacuums
Hoover Legacy 810 Changein the belt
How do I change the belt\
    President:
  • 1,673 Answers
Take the bottom plate off, brush roll and belt are there. If you can't see the motor shaft to put the belt on, then remove the top cover so you can get to it.
Posted on Mar 06, 2008
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
I have a Hoover Legacy model S3592 and the cord will not retract, it is fully extended. How can I fix this problem? Patty Lester
You may have to dis-assemble the machine to the point where you can gain access to the mechanism that retracts the cord. Then see if it can be fixed or needs replacement. Just don't lose any parts when dis-assembly, and make sure everything is put back together correctly.
Oct 14, 2013 | Hoover Elite & Legacy Vacuum Cleaner Belt...
The brushes wont work
There is! Look underneath for 4 screwdriver pictures and pry the hood off the base at those points. Lift the hood off and you'll see clearly where the belt should go! If you need help here's the genuine hoover belt replacement you're looking for.
http://www.vacuummedic.com/product.php?id=8
Good Luck!
Aug 11, 2012 | Hoover Elite/Legacy Upright Agitator Belts
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
HOW DO YOU REPLACE THE BELT ON A HOOVER US140-900 WIDEPATH TEMPO VAC
To help you in your efforts to change your belt here are some good resources. This is the manual for your vacuum. It explains how to change the belt:
Manual for HOOVER U5140-900 WIDEPATH TEMPO VAC
Here you can get replacement belts for your models:
http://www.vacbelts.com/hoover-40201160-belt.htm
Oct 20, 2009 | Hoover S1410 WindTunnel Porta Power Bagged...
My hond spin sprayer on my Hoover Legacy series
it is clogged. the hose part were it sprays is most likely to be clogged with debree. It happens all the time with hoovers
Sep 11, 2009 | Hoover Vacuums
I am trying to change the belt on a hoover legacy dirt finder. I cannot figure out how to get to the inside pully where the belt hooks
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=733898
Generic problem for all Vacuums
Posted by fuzzyplus1 on Jul 02, 2008
I am trying to change the belt on a Hoover legacy dirt finder. I cannot figure out how to get to the inside pulley where the belt hooks.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Hoover legacy belt change can either be changed from the bottom of the vacuum by either taking out the screws, clips or levers, and then you can remove the bottom plate or the top cover, what ever the case might be. Then you can cut off the old belt and then guide the new belt onto the motor pulley by using a long nose pliers or a screwdriver; if it is hard to reach and then take the brushroll and slide it inside of the belt and then pull back until the brushroll will fit into the brushroll holder, then you can replace the top cover or the bottom plate and reverse the procedure that you did to change the belt. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Vacuums
Changing a belt
Take off the bottom plate, look in the bottom to see if there are any screw, could be 2 of them, then from the bottom there is a slot on each side of the top cover, using a flat screwdriver, insert blade into the slot and pry up to release the locking tabs. Belt # is 38528040. Put the bell over the brush roll, put belt thru opening and put atound the motor shaft, put back together.
Jan 22, 2008 | Vacuums
Vacuums Logo
646 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
