Question about Speed Queen AWS75NW Top Load Washer
Selector switch my washer only works on delicates settings it wont work on other settings like regular and etc/ What seem to be the problem?
    Sergeant:
  • 351 Answers
It could be a timer fault,or a motor fault but i would go for a timer.unless you have any buttons pressed in you shouldnt.hope this helps.
Posted on Mar 14, 2008
Kenmore model 2495-4301. When closing the lid to begin any cycle, there's a metal clicking sound coming from the area of the bottom. The agitator will not move in any cycle. Just that clicking sound..
I had a similar problem with my washer. It was clicking, but the agitator was moving fine. The clicking was coming from the centrifugal switch. After checking the capacitor I was about the give up and call a repair tech. Then I noticed the Speed Selector was set between Delicate and Normal. I moved the selector to a proper position and the washer stopped making the clicking noise and is working correctly.
Feb 08, 2011 | Kenmore 24952 Top Load Washer
Maytag PAV2300AWW, ONLY WORKS ON REGULAR CYCLE. ON DELICATE CYCLE CLICKING NOISE LIKE SWITCH OFF AND ON AND AGITATOR WILL MOVE SLIGHTLY WHEN CLICKS. MY SON HAD IT ON A WHILE BACK ON THE DELICATE CYCLE AND...
Your timer is bad on that cycle. It is okay to use on regular cycle, but I would not use it on the delicate cycle, or will you burn up your timer. You should be home when using this, so if it does act up you can catch it.
Dec 01, 2009 | Maytag PAV2300 Top Load Washer
The washer will not fill when the temperature is set to cold. However, the washer will fill if the timer is advanced to rinse (which is always cold). This occurs for both regular and delicate cycles. Is...
It's going to be your timer. It has points inside. The point the sends power to your selector switch at the beginning of the cycle is burned.
Please ate solution
Sep 08, 2009 | Maytag Washing Machines
Shakes violently in the spin cycle
hi...
the reason it shakes violently is because
1)Most noisesfrom a washing machine occur during the spin cycle. If you hear loudthumping during the spin, the load of clothes may have becomeunbalanced. Stop the washer and redistribute the clothes, then re-startit. Repeat these steps if necessary.
or else the other reason may be
2) If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch Ifyour washer has a selector switch on the control panel, make sure thebutton for your selection is pressed all the way in, or set properly.
Clutch assembly ManyGE®/Hotpoint® washers use a clutch and an automatic shift lever. Thisassembly is quite complicated. If there's a problem with it, youprobably should contact a qualified appliance repair technician.
Drive motor manywashing machines have multiple-speed drive motors. Though it'suncommon, the drive motor may work fine on one speed but not onanother. If the drive motor has failed on one speed, you need toreplace the entire motor.
On something like this you will need to
remove the washer wrap toinspect the suspension springs & base assembly. Be sure the shippingpins have been removed. The tub should float freely.
I think my solution would have helped you...rate for me if it is been useful.....thank you for using fixya....
Jul 20, 2009 | Admiral Washing Machines
Wash cycle won't start after the tub fills up with water.
There's no delicate or regular spin or agitation If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
May 07, 2009 | Washing Machines
GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Machine stopping mid-cycle
Selector switch
Clutch assembly
Drive motor
Mar 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE washer model WNSR3120
Selector switch
Clutch assembly
Drive motor
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | GE Washing Machines
Amana LWA40AL will not go to agitate cycle
Sounds like a timmer to me.. got a couple bad cycles too bad its the main cycle
Aug 16, 2007 | Amana LWA40A
Washing machine wont work on certain settings
the selector switch for loads is just a switch that connects parts of the timed cycle to the timer circuit. if the timer is not rotating then nothing will work. check the connections through the selector switch. burnt or melted contacts within the switch calls for a new switch. try repair clinic dot com for a replacement.
Apr 19, 2007 | Maytag Dependable Care LAT9706
Speed Queen AWS75NW Top Load Washer Logo
148 people viewed this question
Top Speed Queen Washing Machines Experts
Charles T Nevin
Charles T Nevin
fta777
Mike
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
