SOURCE: Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Hello to all, there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch, thanks jim.
SOURCE: Ionic Breeze - Press Blue - Press Geen button
The blue means the germicidal lamp is operating. Re: green light - Normal operation at all power levels involves a pre-programmed cycle of altering high and low air movement. Press the the green to override the regular power control setting and run the unit at maximum power for five minutes. Your previously selected power level will resume after the five minutes has elapsed.
SOURCE: ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
SOURCE: Where can I have a Ionic Breeze Quadra Model S1637 repaired?
Try this link, pair for $10- http://breezerepair.com/parts.html
Hi miajane131, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
News accounts of a lawsuit concerning that model make it doubtful and not recommended that you should repair it due to ozone:
http://www.latimes.com/health/la-he-skep...
http://www.airpurifierguide.org/faq/what...
