Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
I've had a problem with the door not locking, so i played around with the interlock switch and got it working. It fills up with water but when it get to the drain or spin cycle the door lock light fades and you can hear an intermittent buzz. Any ideas???
Kind regards
  • 30 Answers
Try replacing the interlock first then check the the continuity in the interlock lead
Posted on Mar 07, 2008
Hotpoint wd62 had to bang door to make it work, now stopped altogether could it be knackered interlock.
In a word 'yes' and glad you know our technical jargon!
It calls for a call- to your local service engineer unless, that is, you can change it?
Good luck,
John C
Feb 27, 2011 | Hotpoint WD62 Front Load Washer / Dryer
I want instruction manual for WD62 aqaurius washer dryer
Hi
I have one. I can scan it for you but not sure what to do with it then!
Jun 17, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD61. Door lock light went out before drum stopped after spin prog, now can't get anything to work. I think the Door micro switch or plug fuse... Can you think of anything else to check? How do I...
hi you need to take off the clip thats around the seal ..pull seal away....the switch is held in with two scews ************** TURN APPLIANCE OFF AT WALL PULL PLUG OUT ************** undo scews take interlock out and replace.hope this helps.01179512835
Dec 30, 2009 | Hotpoint WD62 Front Load Washer / Dryer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum wont spin
Check brushes in motor, replace if worn
Oct 01, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Mar 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
202 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
