Question about Samsung Cameras
I have a Samsung digimax cyber530 that turned on with the lens coming out but will not do anything else (blank screem etc) I've put new batteries in and although when I press the power button the green light flashes - nothing happens.
I was borrowing the camera so the simple solution was quality long life batteries than the cheap versions (even though they were new) I had installed.
Posted on Mar 07, 2008
I have a digimax s500/cyber530 When i turn the camara on all that happens is a loud bleeping .and the lense will not come out also it emediatly turns off
be sure battery is fully recharge, if it not replace it with the same rating. also check charger it may not operate well.
Feb 18, 2011 | Samsung Cameras
My camera lens is stuck. I turned it on, it ran out of battery, it turned off, the lens stayed open, put new batteries in (positively the right way), turned on, blank screen, lens won't shut.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Nov 26, 2009 | Samsung Digimax S500 Digital Camera
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Camera won't come on, screen stays black, and the lens is stuck out.
it could possibly be the brand of batteries used sometimes they are not juiced enough to hold out for the camera i have had this problem too i used different batteries til i found one that works
Sep 30, 2008 | Samsung Digimax S630 Digital Camera
Samsung digimax s700
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 21, 2008 | Samsung Digimax A400 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Camera will not take pictures
Try a different brand of batteries. I found that my Samsung S85 went completely bonkers with some (unbranded) Nimh batteries I had. I switched to Engergizers and it's been fine ever since.
Also go into the camera settings and see if you have an option for which type of battery you are using (Nimh vs Alkaline).
Feb 17, 2008 | Samsung Digimax S630 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Sansung digimax s5oo
close the lens on the camera all the way!
Oct 15, 2006 | Samsung Digimax S500 Digital Camera
Cameras Logo
75 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
