Question about Dishwashers
Haier dishwasher dw12-pfe2-u
On the control panel of dish washer 4 lights flashing and beeping j1,j2,j3,j4
dw12-pfe2-u
  • rmg5 Apr 22, 2008
    Same problem $ lights flash and beep . Sounds like its still trying to drain too
  • Anonymous Apr 04, 2009
    Exactly the same problem. Contacted Haier but not much use. Have emailed to comlain about service and awaiting response. Did you have any luck?
2 Suggested Answers
  • 4088 Answers
SOURCE: DIshwasher drain clogged Haier dishwasher model DW12-PFE2-E
Remove the drain hose from the sink drain assembly and force air into the hose--The clog should spit out into the washer cabinet. Make sure the drain hose doesn't have any kinks or sharp bends. Hope this helps.
Posted on Nov 21, 2009
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
Problem with the terminology and interpreting the circuit
Can you take in-focus photo of wiring diagram shown in timer manual, and attach them to comment?
1) Copy following links:
http://waterheatertimer.org/images/Wire-GM40-timer-600.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Right now, dec 2012, there is no product manual for this timer.
Thank you for including the terminal markings.
3) I assume jumpers are for changing voltage?
Please add comment and say what your product manual says about J1 J2 J3 J4 jumpers.
4) Load is water heater
Timer is clock that is set and programmmed to turn switches on-off.
NC is normally closed > when timer is OFF, NC and NC2 terminals are ON
NO is normally open > when timer is OFF, NO and NO2 terminals are OFF
When timer turns ON, then the switching reverses, and NO terminals turn ON, and NC terminals turn OFF.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 16, 2012 | Hardware & Accessories
We have a Haier DW12-PFE2-U dishwasher thats 2 years old. The cycle stopped yesterday leaving an amount of water in the bottom and all of the program lights are illuminated with a recurring beeping sound...
Refer userr guide on page 21. It reads...
When all the programme indicators " J" blink.
Have you checked whether:
the door is closed properly.
The door switch could be the problem or the door seal is pushing the door open. May need replacement.
May 19, 2011 | Dishwashers
DW12-PFE2-U lights up but will not start program
Well first of all you can check out the door switch - The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it. Your switch also may be locked in place by a locking clip. If this is the case there should be a button or a lever that you can press or pull, which will release the switch and it can simply be removed. Please post comments for further help or information........
Good Luck!!
Thanks
Jun 07, 2010 | Haier Dishwashers
Nov 21, 2009 | Dishwashers
I have a DW12-PFE2-2 the dishwasher tablet does not dissolve,it is still in the dishwasher detergent dispenser after wash has finished?
HI Accumulated detergent from prior washings can cause problems with the soap dispenser. Buildup can get into the soap dispenser and interfere with the spring that triggers the flip-out tray, or it can slow down the pivot action of the tray. If the dispenser is not opening, first make sure you aren't loading the machine so dishes or pots and pans are touching the dispenser, and that dish racks aren't blocking the dispenser. Also check to make sure the dispenser tray isn't cracked. If leftover detergent in the tray is almost liquid, rather than just damp, the tray may be damaged.
If you can't solve the problem easily, replace the entire dispenser unit. This is usually easier than trying to disassemble it and replace separate parts. Use a new dispenser made for the dishwasher. The screws holding the dispenser in place may be on the front of the unit, or you may have to remove the front door panel to get to the screws and make the replacement. Remove the old dispenser and secure the new one, connecting it in the same way the old unit was attached.
THANK U,,,,,,,,,,,,,,,,,,
Sep 12, 2008 | Haier Dishwashers
Excel functions
Here's one way to do it. Your formulas would look like this:
B1:
=IF(OR(J1=1, J2=1, J3=1, J4=1, J5=1),1,0)
B2:
=IF(OR(J1=2, J2=2, J3=2, J4=2, J5=2),2,0)
B3:
=IF(OR(J1=3, J2=3, J3=3, J4=3, J5=3),3,0)
etc.
If you don't want the zeroes to display, format the cells with a custom number format--type: 0;-0;;@
Nov 14, 2007 | Computers & Internet
Dishwashers Logo
391 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
