Question about Hoover F5881-900 Vacuum
Cleaning hose I can't get solution to come through my hose attachement to clean furniture
After you use the 5358-900 vac how do you clean hose for next time
Posted on Aug 15, 2011
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=428640
Cleaning hose
Posted by NNate on Mar 06, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. It sound to me that you may have a defective pump or switch, the sprayer or solution should not spray out unless you use the trigger. Question? How old is the machine – if it is less than one year this would be covered under the Hoover factory warranty and if it is more than one year than you may want to check the trouble shooting part of the owner’s manual or to call the Hoover tech support line @ the factory. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 16, 2008
I have a Hoover Deluxe Spin Scrub carpet cleaner that has lost suction. I read the solution by Chris Jones of GoVacuum.com, in which he described the design flaw whereby the tool attachment hose tears at...
A tear in the hose will only affect pick up through the hose when using it to clean furniture, stairs, and such. It will have no effect on the carpet cleaning operation. If the hose cannot be replaced for a while, black electrical tape is one solution to seal the crack.
Mar 29, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Where do u attach the the hose to get suction for cleaning furniture?
Tried to track this down, but did not find anything specific. I did find a URL that shows the detachable hose with written instructions (very short) about attaching it to the unit. If you have the owners manual and go to the URL, you might be able to answer the question.
http://www.vacuumpartstore.com/mof59f59f59f.html
Paul
Oct 06, 2010 | Hoover SteamVac F5914-900 SpinScrub...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
How to attached stair cleaning attachment
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
tube.
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
tank.
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
position.
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
GoVacuum.com
Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
Hoover steam vac
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Aug 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook the parts for cleaning furniture
How to Clean Wooden furniture The tips below explain how to clean wooden furniture, but an essential part of everyday maintenance is to place protective mats or pads under them to prevent the wood from scratching - otherwise, your efforts will be in vain.
  • If you're wondering how to clean wooden furniture on the regular without much hassle, regardless of the wood finishing, you should get rid of the dust first.
  • Make sure to attach a dusting brush to your vacuum cleaner to remove the dust on your wooden furniture to avoid scratching it. If you do not have a dusting brush attachment, opt for a soft microfiber cloth instead.
  • Then apply a specialized wood cleaning product - always follow the instructions on the label, and choose your product to suit the finish on your furniture. Read on to find out which to use
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 17, 2008 | Vacuums
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
F5888 900
Doesn't attach at the bottom. If your hose has a block on the one end, take the lid off of the dirty water tank, pull out the block on the front on it and install the block on the end of the hose. Don't forget to put that other block back in when you are done or you won't have any suction.
Nov 11, 2007 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Hoover F5881-900 Vacuum Logo
136 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
