Question about HP Pavilion 734n PC Desktop
How can I remove dvd-rom drive in HP Pavilion 734
I have removed the power supply but something is still stopping the drive from coming out fully.
  • potterwiz Mar 09, 2008
    Found the answer. The plastic front panel has to be removed, it is retained by three clips either side. Once the panel is removed the drive will come out the front. Thanks for trying.
    It does, but the plastic front of the PC has to be removed first, it is held in place by three clips either side.
To remove the dvd drive first remove the side panel holding it are 2 screws that you can twist off with ur hands disconnect it and slide it out
Posted on Aug 10, 2009
I think it slides out the front
Posted on Mar 06, 2008
How do i change the cd rom on a hp pavilion laptop
Hello Turn off your Pavilion laptop and remove the AC power cord. Slide the battery release lever to the unlocked position and remove the battery.
Read more: How to Remove a CD-ROM Drive From a HP Pavilion Notebook N5425 ' eHow.com http://www.ehow.com/how_6138972_remove-hp-pavilion-notebook-n5425.html#ixzz2BTQ7dMMi
Remove the small Phillips head screw on the bottom of the laptop. This screw is used to secure the optical drive to the laptop case.Grasp the front of the CD-ROM drive and carefully slide it out of the bay. Slide the replacement drive into the bay and secure it with the Phillips head screw. Then replace the battery, connect the AC power and turn the laptop on.
Good luck
Nov 03, 2012 | Computers & Internet
Power supply is shot. Need instructions on how to replace it.
When you remove the cover off the desktop case you will see the leads from the power supply to the hard drive, CD/DVD drive etc and power connectors to the motherboard.
Unplug the leads and unscrew the 4 power supply mounting on the back of the case.
You can now remove the power supply.
When you purchase a new switch mode power supply make sure the total wattage of the new power supply is the same or greater than the old power supply.
Jun 11, 2011 | HP Pavilion a1440n PC Desktop
I have a hp pavilion a562n computer and im looking to replace my dvd drive. Can you give me a detailed guide on how to do this???
Go to this link
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=408385&
Its to the manuals of that computer. Select PART REPLACEMENT INSTRUCTIONS. Download the file. The file is a pdf file that shows you how to remove it and install it.
hope that helps
Oct 26, 2010 | HP Computers & Internet
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
How to get motherboard out of a hp pavilion 524w
On the outside, disconnect the power-cable, then the keyboard/mouse/video/audio/USB/printer cables.
Disconnect all the cables from the power-supply to the devices (disk, CD-ROM) and to the motherboard.
On the outside-back, remove the screws holding the power-supply in position, and then remove the power-supply.
Remove the screw holding each add-in card (audio, video, modem).
Remove each of the add-in card(s).
Remove the ribbon-cables from the motherboard to the diskette & disk-drive & CD-ROM.
Look for screws holding the motherboard to the case.
Remove those screws, and gently lift out the motherboard.
Oct 31, 2009 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
Replacing power supply for pavilion 3000 desktop. How hard is it to do?
no it is not hard. Open the side of the computer then unscrew the screw that is at the back of the CPU. Remove the wires that's connected to the CD rom, hard drive and mother board before removing the whole power supply. then you can replace in that same position as you see the previous power supply.
Mar 15, 2009 | HP Pavilion a705w PC Desktop
No battery
check if the battery is charged fully ...?? if not try to start the laptop on Power ...and charge for atleast 1 hour...then see the backup of battery by removing power cord..
Jan 03, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Dvd/cd writer, and dvd rom drive does not work
Check if you have both cables attached to the CD/DVD drive. There are usually 2 that needs to be connected: the SATA or IDE (that ribbon-like connector that goes right to the motherboard), and the power supply (a connector that has 4 colored lines going to the power box). Make sure they are snug, and if necessary, try changing them with others that are known to work (there should be lots of spares). If the CD/DVD light blinks or powers on upon boot, it means power line is OK, but data cable connection is bad.
Sep 06, 2008 | HP Pavilion (PN153AAR) PC Desktop
HP Pavilion DVD drive replacement Vista
not too difficult
remove side panel of pavilion
tabs inside of chassis, near front of unit, press in gently. There are two or three of them
remove front panel from chassis
either remove the screws holding the dvd or use the green slider
unhook dvd from cables and power supply
slide out
reverse for installation
make sure you get new drivers from site(like this one) and resist temptation to use cd supplied
Mar 09, 2008 | Computers & Internet
HP Pavilion 734n PC Desktop Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
