Question about Dryers
How to clean the duct from my clothes dryer?
I have a Whirlpool Model #LER6848AW0 Serial #MD1119304
but I don't have the $95.00 for a professional to come or I could take my dryer for him to clean it.
  • meoby Mar 06, 2008
    I was told to pull out the dryer but I too cannot afford to do pay $100 or do it myself--so the Sears guy gave me an idea to use my leaf blower and put it on suction; since I have an existing hole reachable in the vent from where a service cleaned it last year.
    Problem is...I cannot figure out how to switch my leaf blower to vacuum! This dryer vent plugs up so fast I because when Kenmore made these dryers the doors were not able to be switched from one side to the other!!! Thx, meoby
  • 156 Answers
If the vent is pluged dryer to out side go to home depot by the 4 in dryer vent brush with a 8 to 10 ft cabel on it feed it in the vent pull turn till it comes out the ather side you also should have inside dryer cleaned out if its pluged from the back up lint going inside dryer
Posted on Mar 06, 2008
Whirlpool gas dryer takes longer to dry though it heats up and turns, yet it has a humming/buzzing noise. What could be the problem?
Had the same problem. There was a bit of a kink in the vent duct which caused lint to build up in duct and also inside the dryer itself over years. I replaced the duct and took dryer apart and cleaned out the air passages.It works great now. As for the humming, mine started about 2 1/2 years ago and I still don't know why.
Jun 04, 2012 | Whirlpool Dryers
Dryer is smoking and clothes are too hot to touch
Tara, We are sorry to hear about your Dryer. We are happy to look into your concerns but we will need your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase emailed to Whirlpool_Digital@whirlpool.com.
Jun 07, 2017 | Whirlpool WED5300S Electric Dryer
I have a GE washer/dryer Model WSM2700RAWWH stack type and the dryer is taking very long time to dry the clothes. Please advise if it can be fixed. If not what will be best alternate washer/dryer stack...
first things first. if any dryer regardless of brand takes 2-3 hours to dry cloths 90% of the time it is your exhaust duct. take the exhaust duct off the back of the dryer and dry some clothes if the clothes dry fast then you need to have your exhaust duct cleaned. either DIY or call a professional
if it still takes a long time to dry then it could be the thermostats or the thermistor.
but in my experience its normally the exhaust duct.
Feb 10, 2011 | GE Washing Machines
I recently had the heating element replaced on my whirlpool electric dryer model #LE5800XSW3. Prior to replacement, clothes dried completely in one cycle. After replacement the clothes take at least two...
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 22, 2011 | Whirlpool Dryers
My whirlpool 6th sense dryer model awz3413 turns off when clothes still very wet. Lint filter light comes on but filter cleaned and outlet ducting has been vacuumed. Could this be a senor or thermostat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Aug 25, 2010 | Whirlpool ET8CHEXSQ Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Dryer model #le86000kq1...clothes are taking long time to dry..have to repeat drying process several times before clothes are actually dry
Candace-
It may be as simple as dryer duct needs cleaning. I provide that service to several of my commercial customers in group homes. When the duct work is partially closed from build up it reduces dryer efficentcy. Also if you have flex vinyl duct work replece it, its a fire waiting to happen.
Nov 11, 2009 | Whirlpool Dryers
Clothes not getting dried
Are you sure that the duct is clean and free flowing? If the duct is partially blocked the dryer's efficiency drops dramatically. I would double check the duct at both ends and clean out as required - air flow is very important - with the dryer on - go check the air coming out of he duct outside - if it is very forceful - then the problem is elsewhere - however if only a little bit of sir is coming out - your all plugged up!.
Nov 19, 2008 | Kenmore 63942 Dryer
I have a whirlpool super capacity dryer that is very slow drying the clothes. It takes three or four cycles to dry a load of clothes. I've cleaned the lint screen.the exhaust tube and the clothes aren't...
hi .your air duct in the dryer is probably clogged . To repair. remove lint filter 2 screws on the top, remove . lay dryer on floor, front down. remove back panel . remove the air duct, clean all lint thanks the appliance doc
Oct 02, 2008 | Whirlpool Dryers
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Dryers Logo
308 people viewed this question
Top Dryers Experts
