Toshiba TV - picture incorrect size
I have a Toshiba 28z33b analog tv. The picture appears to be cut off at the sides i.e sometimes text is only partly visible - this is on all spects. The menu doesn't offer a suitable adjustment - I wonder if there is a simple control inside the casing?
  • 1 more comment
  • ronhud Mar 07, 2008
    Still wonder if I can deal with the problem myself so any info on this is appreciated
    As mentioned in the question the display is cut off at all aspects - i.e all available ratios, wide, cinema,4:3 etc. If I can find out the component description and location then I might be able to search for a replacement and fit it.
    Called in a TV repairman - he is collecting tomorrow.
    Brigadier General:
  • 6,966 Answers
With the indulgence of the others....
Can you post an image of the screen showing the "cut off at the sides". The image has got to be 150kb size or less otherwise the system will reject.
Offhand, if the unit was operating fine before, then I can only suspect a component failure. If the unit is a couple of years, then it is possible that the main capacitor (at the power supply) or some other component(s) would require replacement. Should this be the case, then what you're seeing as "cut off at the sides" could be low B+.
Can you also please post back the model number of the Toshiba CRT TV?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 07, 2008
  • Louie  Role
    Louie Role Mar 07, 2008
    Missed the model number, got it now.
  • Louie  Role
    Louie Role Mar 13, 2008
    any development(s) with your Toshiba?
  • 100 Answers
I know,all technician given good solution for u.I suggest u that better to u take from Nearest service center.
Thanks
  • 108 Answers
There should be adjustments for the picture aspect ratio.
Your widescreen television supports Subtitle Zoom, Conventional 4:3, Auto Wide, Cinema, Wide, Super Live. This means for a normal 4:3 tv picture, the tv can chop off abit from the top and the bottom and the sides stretching the picture to 'fill' the widescreen ratio of the TV depending on what 'mode' it is in.
There is a button on your remote which will toggle through these settings.
If this still does not work then - as you mentioned there is likely a POT inside the set to which may be tweaked. However I cannot offer more information on this.
  • dan muggeridge Mar 07, 2008
    I have the Service PDF and Schematics.
    In the service book it explains how to put the TV in to Service mode and then into design mode to correct your problem (Done via the remote control)
    How can I get it too you?
    I'm pretty sure the Service PDF file will ensure that you can solve your problem,
    I'll have a go at explaining.
    If you mess this up you could make things worse...Most TV engineers would probably do this with their eyes shut...
    turn on the TV.
    press the mute button on the remote and hold it down and then Menu button on the front of the TV.
    Use the tv (not remote) Channel UP/Down to select WID. This is picture width.
    Use the tv Volume UP/Down to modify with width...
    Regards
  • 19,396 Answers
You have screen set up to 4:3 search for screen size in your manual and set it up to 16:9 or to letterbox format. Let me know if you need manual or furthet help.
regards
    Guru:
  • 1,894 Answers
Hello sir
  • dewan nafees ahmed Mar 07, 2008
    it cant be controlled by menu sir
    this is due to ICs inside the TV..
    you need a replacements of a few ICs
    tell a tech from toshiba to do it
    thank you
    good luck
    dont forget to rate the solutions
Can't get picture to fill the screen. Black bars
U have a CRT tube analoge standard tv,this feature will not work for a CRT analoge standard tv.Zoom in and out,picture sizes like 480,720 and 1080.The analoge tv can't get the tv signal ranges beyond 480i that why u have black sides bars picture,if u have a HD TV like a LCD tv or Plasma tv,than the Zooming in feature will works.
May 24, 2011 | Televison & Video
My Trinitron's mostly fine, though it's a few years old, but it has a strange display issue. It's almost as though the picture is "zoomed in" about 8%, cutting off about 1 to 1 1/2 inches of...
This problems u are having it is not the causes by the tv,because ur tv it is a analoge CRT tv,don't have this functions zooming in or out or the problems just causes only 8% cutting off edges of the tv pictures only.If the problem it is happening to ur analoge tv it will have no vertical hold at all.The devices u are connected to the tv and using have zoomming in or out buttons or ajustment buttons of the sizes of the picture on the screen.Used the devices remotes controls to readjust ur zooming or pictures sizes adjutment.
May 04, 2011 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Black square in middle of picture
your captioning or "text" is on. usually inside the tv menu. if not its your cable or dish box has captioning on. black box usually means its in text mode instead of CC thus the black box rather than text
Jun 03, 2009 | Televison & Video
Olevia 232-s13 tv - screen is cut off and cannot see top and bott
The TV is set on zoom. Just go to the remote control and look for the button (not sure what is is on olivea usually zoom, P. size, wide, stretch or something similar though). just press the button until you cycle through to normal (on an analog signal it will have black bars on both sides).
Mar 24, 2009 | Televison & Video
Sides of picture cut off on Toshiba 27D46
Check for dry capacitors on the tv board
Jan 19, 2009 | Toshiba 27D46 27" TV
Picture size/aspect ratio in HDTV and upconverting DVD
In the digital world, you can't have a 4:3 aspect ratio DVD title (720x480) on a 720p (1280 x 720) / 1080p (1920x1080) display without some kind of centering or stretching to some extent. (square vs rectangle) Now, on a 16:9 aspect ratio title (wide screen format) you should have any scaling issues regardless of the pixel resolution. Despite what the sales person told you, trans-coding ("upconverting") lower resolution titles to a higher resolution does not increase the quality of the image. Any attempt to do so would be only to try to reduce block noise and any kind pixelation at higher resolutions. (blurring square pixel blocks)
In the analog world, the quality of the image is based on the encoder and signal depth. If your TV excepts HD analog, you might be able to have your cake and eat it too. That would force your display to convert an analog signal into a digital resolution, letting the TV hardware do all the trans-coding. Manufactures are completely phasing out analog signal receiving, but might have the RGB RCA connectors for backwards compatibility. Eventually, it will not be supported and you will be forced to buy higher resolution content.
Mar 31, 2017 | Televison & Video
Picture on Telefunken 72 cm TV expands beyond screen size
Your screen somehow got switched to theatre/cinema mode. There is a setting on the remote that attributes to aspect ratio. Sometimes it is called "ASPECT". Look for it, and press it until your original screen aspect shows.
Dec 15, 2008 | Apex Digital PF2020 20" TV
Toshiba TV problem with Sky TV
did you try to install directx 9 again ?
Mar 20, 2008 | HP Pavilion dv6000z Notebook
Picture disappearance & tv turns off
It sure sounds like you have a classic case of bad solder joints. Resolder all the connections on all boards.
May 31, 2006 | Toshiba 36A43 36" TV
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
