Question about Seagate (ST3160827AS) 160 GB Hard Drive
160gb hard disk
Hello have resently formated my hard drives and reinstalled windows due to my com not being able to anisulize my 160gb hard drive have reinstalled it but it is only reading as a 31.4gb could you tell me wat to do please
  • louise 1 Mar 06, 2008
    hi ya just put jumper pin back where it was originaly turned com on bios is reading it but windows wont anitialize it again been to disk managment and wont ani wat do i do now
Hello prob . solucation
Posted on Apr 15, 2008
  • 449 Answers
Pherhaps the hard disk has a bad sector on it, and dos automatically partition the hard disk, check the jumper diagram on the hard disk and fix it back to the highest volume. and make sure you run the partition carefully
Posted on Apr 02, 2008
Dfsfds
Posted on Mar 12, 2008
  • 790 Answers
There will two problem
  1. Guess u have not fixed the jumper to a proper place.
  2. Or u haven partitioned the hard disk proprely .
Go to disk management and check whether there is unallocated space is present or not!!!
Posted on Mar 06, 2008
My bio-star p4m800-m7 mother board won't detect my 1terabyte sata hard disk, currently i'm using 160gb ide hard disk....i need to have additional storage...but the system cant detect sata...need...
Hello,Please check the BIOS to see if the SATA ports are enabled. Older boards will disable the sata ports in the BIOS by default. To enter the BIOS, hit the DEl key as soon as you boot the PC.
If ports are enabled, then you probably have to format the drive.Heres how:1. Right-click My Computer and select Manage.
2. Under Storage, click Disk Management on the left pane.
STEP 3 - Format the device / drive / MP3 player
1. Right-click on the 1 TB drive you want to format then select Format.Windows will not recognize the drives file system and will mount it with a drive letter. ex; E:
Sep 09, 2011 | EliteGroup P4M800-M7 Motherboard
Blue 500 GB not recognized by Sony Vaio laptop
Hello, Assuming the drive works and the laptop's usb port is good then the problem could reside in a couple of areas.. 1. The file system of the Blue hard drive may not be recognized by windows on your Vaio, this is most likely due to the fact its was formatted with a Mac (and therefore probably using HFS). If this is the case and you need to read the contents of the disk then you can install mediafour's macdrive (http://www.mediafour.com/products/macdrive) this will allow your vaio to read the mac disk. It is free for 5-days so if you just need to access some files you can do this at no cost. 2. The drive may not have been partitioned and formatted yet, in which case for windows XP follow this microsoft guide http://support.microsoft.com/kb/313348 and for windows 7 follow this http://windows.microsoft.com/en-US/windows-vista/Create-and-format-a-hard-disk-partition
Hope this helps
May 04, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Hard Drive lost capacity
You cannot just 'loose' most of the capacity on a hard drive unless you have some serious issue and if that was the case, I would not even recommend you using it! What I suspect, because of its size, is that you are only seeing one of the formatted (recovery) partition. In order to use the rest of the hard disk, with the proviso that you want to keep the existing small partition, you need to create and format additional partitions. This is not a trivial task, but the following is the summary on where to find the facility: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk will be displayed with all existing partitions: after which you can use the context menu to delete/create partitions, Format partitions and assign a drive letter so that you can use the formatted partitions. Hope it helps: let me know how you go!
Jan 01, 2010 | Western Digital Caviar SE WD1600AAJS 160...
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
May 17, 2009 | Smartdisk - Peripherals - HARD DRIVE,...
Hard disk siz problem
Use Partition Magic to parition and format the hard drive.
Apr 26, 2009 | Seagate 750GB ST3750640AS SATA300 16MB...
Break down of 160GB hard disk
Very old hdd. They have not produced a hdd smaller than 640GB for over 10 years.
Sep 27, 2017 | Compaq tc4200 Tablet PC
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
Seagate Barracuda 7200.7 160GB
You don' t say what OS or even type of computer (PC, Mac, Windows XP, 98, vista etc) you are running, or whether the drive has been used before. If it's a new drive then it probably needs formatting, so you can allow the OS to do that. If it contains data that you need then DO NOT allow the OS to format it.
If you know it is formatted & contains data, then it sounds like the OS is not recognising the format. Windows 98 typically won't recognise NTFS disks formatted on Windows XP for example or Linux Ext3/4 format disks won't be recognised by Windows. In the latter case, you can download a free driver which will do that for you - google Ext 4 and Windows.
Aug 26, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
My hard disk
the 7GB is probably the first partition from previous installation. You will need to delete all partitions on drive and then format the drive, that is if all is backed up. once that is done you can create a few "new" partitions and install Windoze to the first partition. make sure to make that one active and/or primary. the other partition you can use for Data.
Jun 27, 2008 | MSI KM4M-L Motherboard
Formatted hard disk on pc now it won't run on mac
Try plugging your hard drive into your mac, open "Disk Utility" select your hard drive in the list on the side, Click RAID, change the Volume Format to MS-DOS (FAT), and it should work.
Hope this helps!
Apr 03, 2008 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Seagate (ST3160827AS) 160 GB Hard Drive Logo
148 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
