Question about Texas Instruments TI-89 Calculator
TI-89 Won't Turn On
I haven't used my TI-89 Titanium for about 2 years. I just tried to turn it on, and it won't turn on. I have replaced all the batteries. What do I do?
  • 4 more comments
  • jenniferni68 Jul 21, 2008
    My TI-89 was working two days ago with fine battery and now it wont turn on (new batteries and everything).
  • pinkruby Nov 14, 2008
    I have not used my TI-89 Titanium calculator for about 6 months. November 11, 2008 I just tried to turn it on, and it will not turn on. I replaced the four AAA batteries and the back-up battery by the all new batteries. It will not turn on.
  • Anonymous Dec 13, 2008
    new batteries, was working 3 days ago, won't turn on
  • dave408 Jan 29, 2009
    Mine doesn't turn on... hadn't used it in about a year and a half... one of the old batteries looked like it might have leaked, but I don't think any material from the batteries got inside. Just in case I put some baking soda in the battery compartment, blew it out with compressed air, I put new batteries and removed the backup battery and tried the 2nd, left, right, on but it didn't work for me, nor did the blowing in the USB socket. Does TI have a service facility that would cost less than a new one?
  • Anonymous Jan 30, 2009
    I've had 3 ti's do the same thing and my 89 just did it. I can't figure it out and i'm a freaking engineer.
  • linamavilla Apr 02, 2009
    I haven't used my TI89 Titanium for about six months. I was going to use it and now it doesn't turn on.
    I replaced the AAA batteries and it worked out for about a week, then, when i was using it, i turned off suddenly. I replaced the backup battery and now it doesnt turn on.
  • 8 Answers
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  1. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
To reinstall the Calculator's operating system, take a look at the following TI site.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
Posted on Jan 30, 2009
    New Friend:
I had the same problem I check each one of the battery connector and notice that one was missing, search for it in my bag, find it and put it back the plastic that hold the connectors is of very bad quality check that
Posted on Nov 17, 2014
  • 8073 Answers
SOURCE: The TI-89 Titanium calc. purchased in Oct. 09 won't turn on
Try to increase the contrast
1. Turn it on
2. press [2nd] and release button
3. Press [UpArrow] and release button
4. Repeat steps 2 and 3 until contrast is adequate.
If that does not work use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html
Install it on your computer and run it to oppen the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK..
If all that does not work, then it may be time look for a repair shop.
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
Hope it helps
Posted on Sep 12, 2009
  • 749 Answers
SOURCE: TI-89 titanium does not turn on
have tried replacing its batteries!
Posted on Nov 04, 2007
raklein62
  • 360 Answers
SOURCE: TI-89. Don't turn on.
I've did the same thing but, with Ti Connect Device Explorer software, I was able to reinstall the OS software. If it is that unresponsive take out all batteries including the backup battery for about 4 hours. I had to do that one time just to get unlocked from the graphing APP. Ti one time told me to miss with the arrow and ESC keys, and it works sometimes. Good Luck, and I hope this helps your posted problem.
Posted on Sep 14, 2009
raklein62
  • 360 Answers
SOURCE: TI-89
If you make a custom, you can have the Toolbar F function keys operate as 7, 8, & 9. If you respond with a rating I'd even write one out for you, and make it where you just hit [2nd] [CUSTOM] for the use of those keys.
Posted on Sep 15, 2009
raklein62
  • 360 Answers
SOURCE: When I turn the switch on, ti-89 titanium does not turn on.
If you connect calculator to computer using Ti connect device explorer you might be able to see what files are on the calculator. I don't know if you downloaded from the web but, 3rd party programs and shells tent to miss up the calculator. This would able you to delete out possible problems which could be re installed later.
Posted on Sep 22, 2009
My ti 89 won't do the simplest of d'dx's. Some suggested that there may be something with the memory. Also, it's not the Titanium edtn.
You could be having a variable "problem". Go to home, select clean-up. You will see: clear a-z variables. Click on it. Hope this helps.
Sep 25, 2012 | Texas Instruments TI-89 Calculator
Ti-89 titanium diagnostics
There is no DiagnosticsOn command in the TI 89 Titanium. The command exists on the TI83/84PLUS where it displays the r and r^2 coefficients. On the TI89 , the correlation coefficient and the determination coefficient (r, r^2) are displayed by default among the statistics if THE REGRESSION MODEL includes them. If they are not defined by the regression model they will not be displayed. In short, you do not have to turn diagnostics ON.
Apr 17, 2012 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
Ti-89 titanium
Having gone over a month with no response, I assume this is no longer a problem.
Jun 26, 2010 | Texas Instruments TI-89 Calculator
Sep 22, 2009 | Texas Instruments TI-89 Calculator
Ti 89 Titanium
The only option or keys that will work is the ENTER key and the arrow keys. Try to get your arrow key to work by arrowing down and hit enter hopefully change you to something different.
Next, if at all possible can you hit the MODE key or get into the mode. If you get into the MODE select F3 and then arrow down twice or all the way to the bottom and at APPS Desktop select 1:OFF and then hit the ENTER key. Next, What I really think you need to do is reinstall the Ti 89 OS software. To do so you would need to connect to your computer or another Ti 89 Titanium to your Ti 89 Titanium. If you have Ti connect computer software (from the Ti site) connected to your Ti 89 Titanium it might help you more in troubleshooting any further problems too. You might be able to delete corrupt files that would free your calculator up and start running better.
Sep 03, 2008 | Texas Instruments TI-89 Calculator
Ti-89 Doesn't Turn OFF!!
1) Update the OS from the TI site.
2) check if button is sticking(not necessarily just the plastic button, but what it hits on the inside... you can clean the contacts on the inside of the calc with a Q-tip and rubbing alcohol.)
I don't have much experience with this specific calculator but those are my best bets.
good luck
-Saik0Shinigami
Oct 31, 2007 | Texas Instruments TI-89 Calculator
My TI -89 won`t turn off
Solution that worked for me, taken from "Ti-89 titanium wont turn off":
Best Solution posted on Mar 05, 2008 Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was able to fix the problem nut it requires several steps and only offers a temporary fix (untill the calculator is reset then it needs to be done again).
1. Press F5, then Dimond (symbol on buttion) then "Clear"
2. Press "alpha" then "S"
3. Press "0" dont mess with anything else here
4. Press "2nd" then "Quit"
Now you can turn it off but are missing the bottom text (rad,auto, etc...) to fix
6. Press "Mode" change radian to degree then "enter"
Now the text is displayed showing the mode.
7. Set the mode back to radian by reversing step 6.
Thats it I dont know how to get the bottom line back though...
Oct 25, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
14,088 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
