Refilled Cartridges I want to refill my ink cartridges. Can I get printer to accept these refilled cartridges? I am aware of warranty information and since this was a very inexpensive printer that does not concern me very much. I have already had my printer for a year.
  • dkc1257 Mar 06, 2008
    I ordered them from 4injet. All were specific for refilling my Lexmark printer. The only one that gives me a hard time is the color cartridge. The black and photo seem to print without bringing up any alerts besides "this is not Lexmark Ink" warning.
    Brigadier General:
  • 3,614 Answers
YES! as long as you get the compatible ink for that.
Posted on Mar 06, 2008
  • micromaster
    micromaster Mar 07, 2008
    Just clean first the print head, it has to be clean after each refill.
Printer will not accept new cartridges. Printer is new and wants original cartridges to initialize ink system. Original cartridges are not availible. Tryed reset but did not work.
HP printers will not accept refilled cartridges. Are you trying to replace your empty cartridges with refilled cartridges? There is a computer chip in the ink cartridge that tells the printer when it is out of ink. If you try and refill it yourself, the printer will not recognize that it has been refilled without replacing the computer chip in it.
I think your printer is telling you that it needs HP brand cartridges that are original and not refilled cartridges. There is no way to "reset" an hp printer to get it to use an off brand or refilled cartridge that has not had the chip changed.
You can pick up a good refilled cartridge at a professional company who knows about changing the chip for less then a third of the regular price of an HP cartridge in a department store. However, HP does not want you to use refilled cartridges and should something go wrong with your computer and they find out that you were using them they will void your warranty on your printer.
If you are not trying to replace HP brand cartridges with refilled or off brand versions, I suggest your return them to where you bought them and exchange them. They may be defective cartridges.
Hope this helps?
Nov 11, 2010 | HP C6250 InkJet Printer
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
Check color printer cartridge--I refilled the cartridge the orinter doesn't accept it"
Hi
When a non professionals refill there cartridges
air bubbles are left in cartridges durring refilling process
so when cartridge need ink to heat and spray it on paper has air and that time is when is getting overheat it and need to be replaced
check here how you can refill it your cartridges with no errors on your printer
In case I had help you pls vote me
Oct 28, 2010 | HP Photosmart 2575 All-In-One InkJet...
Printer won't accept refilled cartage
I had a similar problem and i cleaned the chip on the cartridges several times, eventually mine accepted them and started working. I turned the printer on and off several times and re inserted the cartridges before i got mine to work. This happened everytime i needed to change the ink unless i used a brand new HP ink.
Once I went to the shop and got some refilled cartridges and one of them wouldnt work at all. I presumed the old ones i had taken in would be refilled but apparently not. Anyway the shop replaced the faulty one free of charge.
Mar 12, 2010 | HP Office Equipment & Supplies
. HP 6210 all in one Kept printing till unplug
HP will tell you to never refill cartridges because they will not guarantee your printer will print properly with those refilled cartridges. If those refilled cartridges leak and cause damage to your printer HP will also not cover any repairs to the printer regardless of what sort of warranty coverage you have with them. Warranties only cover HP failures, not ones caused by using third-party or refilled ink cartridges. So, no it is not worth having the cartridges refilled - buy new HP-branded ones only.
Jul 25, 2009 | HP Office Equipment & Supplies
I cannot get my printer to recognize my refilled ink cartridges
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
Refilled the black cartridge and now it doesnt recongize it
Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
Ink levels of refilled cartridges
Refilled cartridges usually do not show the correct ink levels. As far as Im aware there is no way to adjust that readout on those cartridges.
Thanks
Aug 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Refilled Cartridges
I've refilled cartridges twice so far. The first time, the black was completely empty and the color was nearly empty. The printer accepted the color refill and not the black. The second time, I refilled both cartridges before they completely ran dry and both were accepted by the printer. The gauges don't register the ink, but it prints just fine. I just monitor the levels through the print quality. A friend with the same printer has told me that she only get 2 - 3 refills before the cartridge has to be reset, and that is a tricky process, but can be done.
Jul 26, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Aug 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Computers & Internet Logo
32 people viewed this question
Alun Cox
David Payne
David Payne
