Question about Kenmore 24 in. 16032 Built-in Dishwasher
  • tadtam21 Mar 17, 2008
    Im having the same problem. motor is much louder and is accompanied by a loud grinding noise we are also in the process of taking it part right now.
    we will let you know if we are successful. my husband has manged to get through to the drive motor its grinding too.
  • 3 Answers
We have located a spring down deep just below the grinding propeller it was twisted and unwound rubbing ageinst the top of the grinder we have removed the pesky sping and are ordering a new one motor is not making any noise now that we have removed this spring. hope this helps you too...
Posted on Mar 17, 2008
My kenmore elite dishwasher 665.17053400 motor sounds like its seized. The machine fills and drains ok but won't do a wash cycle. Moter makes a buzzing noize.
This might help you - this type pump assembly doesn't seem to be a serviceable unit - just replaceable.
May 27, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
My Sears Kenmore Elite will not drain
Pump might be restricted, with food particles, check it pump assembly from inside the cabinet, the drain hose also could be plugged, and finallly make sure that the impeller of the pump itself is working
Dec 23, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 08, 2009 | Kenmore HE2 Plus Front Load Washer
Cannot find part 154 387601 on the kenmore parts page
you maybe looking for the impeller kit req when looking at the motor part lookup on the sear site go lower and check for the impeller kit in the non-illustrated section of the part screen
Aug 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Motor making noise- Kenmore Elite dishwasher
OUCH. Sounds as if your dishwasher pump is bad. Most pumps need to have water in them to keep them cool and or lubricated. it could be an impeller problem and coul be a cheap easy fix. Or it could be a bearing which is a more expensive fix and a little harder to do. I hope this is an older machine and you may want to go ahead and get a new energy star heat saver. Or if it is a new one just repair it.
Aug 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite 137889, grinding noise
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the tub.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
The drum bearing is replaced by accessing the bottom side of the washer, and is a not a simple repair.
May 05, 2009 | Kenmore 13789 / 13782 Dishwasher
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Kenmore 24 in. 16032 Built-in Dishwasher Logo
302 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
