Question about Homedics PS-200 Iron with Auto Shut-off
Cleaning I have alot of mineral build up in my steam cleaner. How do I clean it out?
    Scholar:
  • 104 Answers
There are a few products that will remove mineral buildup.
Vinegar - slow but it works. Let it sit overnight if filling a reservoir.
If it's on a surface saturate layers of paper toweling with vinegar and place on the surface and let it sit overnight. You may need multiple applications depending on the buildup.
Any 'De-Liming' product (containing Hydrochloric Acid) - Faster, but can discolor metal surfaces if left on too long. Wear plastic gloves when working with these products. If filling a reservoir you may want to dilute it with water (50/50) and leave for an hour. You can make a stronger dilution and/or use it full strength, but be careful... De-Liming Acids foam when they hit lime buildup, so be sure to keep the surrounding area protected or do it in a sink.
Keep in mind it will discolor metal so be careful if putting it in a stainless steel sink. Always rinse and flush with clear, cold water immediately after cleaning. Vinegar is the safe way, but takes time and multiple applications :)
Posted on Mar 07, 2008
How to remove mineral build up fron steamfast sf-465
Alternatively, use in your steamfast
  1. Fill the steamer with an equal part solution of water and household vinegar and let this soak for an hour.
  2. Once the hour is up, shake steamer to adgitate
  3. Then, empty the steamer and add a couple cups of mixture through machine.
  4. If you don't have any vinegar to hand, try lemon juice!
Organic Cleaner White Vinegar For Calcium and Mineral Build Up
Removing Mineral Deposits from Household Surfaces
How to Remove Mineral Deposits
Apr 15, 2014 | Steam Fast SF-465 Iron
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
As the steam builds up it constantly comes out of the the blow off pressure valve under the iron. steam will come out of the sole plate when the button is pressed
Clean an iron:
  1. Unplug the iron.
  1. Unplug the iron.
Oct 02, 2012 | Irons
Mineral buildup in my steamer
To eliminate mineral deposits and prevent corrosion on your steam iron, give it an occasional cleaning by filling the reservoir with undiluted white vinegar. Place the iron in an upright position, switch on the steam setting, and let the vinegar steam through it for 5-10 minutes. Then refill the chamber with clean water and repeat. Finally, give the water chamber a good rinsing with cold, clean water.
-From Reader's Digest 150+ Household Uses for Vinegar
Jul 16, 2012 | Rowenta Irons
Rust coming thru pores on sole plate?
You need to get a iron cleaning product to clean your machine. In the future, use ONLY distilled water in your Iron. Distilled water has been turned into steam (leaving all the minerals in the boiler) and that steam condensed back into water so it is absolutely free of minerals (that is what is coming out of your Iron).
Sum up: Clean it using a product designed to clean steam irons. Don't use tap or bottled water - ONLY distilled water.
Get the distilled water at your super market or auto parts store. Get the Iron cleaner where appliances are sold or at your local hardware store. You may have to ask for it.
Thanks for your question.
Jun 05, 2011 | Rowenta Professional DX8900 Iron
When using the steam it spits out sediment on the clothes. I have tried cleaning by holding the steam button.
This happens due to limescale and / or build ups of mineral deposits such as iron in the water. You will need to use a kettle descaling solution or an iron descaling solution available from most supermarkets or home appliiance stores and clean out the debris in the iron. It happens to most if not all irons and cleaning on a regular basis is the only answer or use very expensive 'iron water'
Sep 28, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Iron Cleaning
If steam iron clogs from minerals in water, follow use-guide directions for cleaning, or use a commercial iron cleaner. A fine needle in the nozzle hole may open it again. Sometimes "steaming" will remove lint clogging the iron; fill with at least 1/4 cup water, set it to "steam", and hold in the air or set flat on wire rack over heat and moisture resistant surface like counter protective mat. Let steam until empty. Using only distilled water in steam irons helps avoid mineral buildup. Or if you have burned stains or darkness on the bottom you can Heat equal parts of vinegar and salt in small pan rub solution on cooled iron surface to remove dark or burned stains
Feb 12, 2008 | Irons
Cleaning a cordless iron
You can buy Iron cleaner from the supermarket. It will take alot of flushing. While you are at the supermarket buy some de- mineralised water NOT distilled water
You have been using normal water in the iron which leads to this problems.
Or you can by a Phillips gold based iron with a inbuilt flushing system in which you can use normal tap water. They retail for about $150.00 in Aust.
Jan 16, 2008 | Irons
Homedics PS-200 Iron with Auto Shut-off Logo
305 people viewed this question
Top Homedics Irons Experts
Marvin
Marvin
Are you a Homedics Iron Expert? Answer questions, earn points and help others
